4 Axis TB6560 CNC Stepper Motor Driver Board Controller
Revision as of 10:57, 24 August 2010 by Bogdan.kecman (talk | contribs)
NOTE: This stepper driver board is HIGHLY experimental within the reprap community ( less than 3 known users, none 100% satisfied with their configuration yet)
NOTE: When I contacted ebay seller about the faulty driver board (they delayed sending me replacement) he told he they had received 3 faulty boards at once and were asking which one is mine
You can get it on ebay
here is the original manufacturer's site, in chinese
google translation of the above site
TIP: the model commonly used appears to be a HY-TB4DV-M.
The 'TB' means it uses the 6560 chip ( TA means the TA8435 chip, which is also used on a similar board).
The '4' means the number of channels.
The -M and -N boards have different physical layouts, and may be different revisions of the same basic design, not sure?
Specifications
Input Power 12 - 36V DC Note that many forums state that this board dies in smoke if powered over 24V
Stepper motor drive current 1.5A - 3A/phase
Drive type Double-pole constant flow PWM actuation output
Compatible Stepper motors 2 or 4 phase, 4,6 or 8 lead stepper motors, 3A max.
Dimensions 18 * 11 * 4 cm (L*W*H)
The pinount in the provided document was wrong (completely) so I traced the pcb for real values and here they are:
DB25 Connector Pinout:
Pin LPT Driver
1 (strobe) X-CW/CCW
2 (D0) RELAY (heater)
3 (D1) Z-CLK (step)
4 (D2) X-ENABLE
5 (D3) Z-ENABLE
6 (D4) Z-CW/CCW (direction)
7 (D5) Y-CW/CCW (direction)
8 (D6) E-CW/CCW (direction)
9 (D7) E-CLK (step)
10 (ACK) INPUT (limit switch)
11 (BUSY) INPUT (limit switch)
12 (PE) INUPT (limit switch)
13 (SEL) INPUT (limit/stop switch)
14 (AFEED) Y-CLK (step)
15 (ERROR) N/C
16 (INIT) X-CLK (step)
17 (SELIN) Y-ENABLE
18 GND GND
19 GND GND
20 GND GND
21 GND GND
22 GND GND
23 GND GND
24 GND GND
25 GND GND
You may find that the fourth stepper driver enable pin is not available on the DB25 connector. If so, it is on the DB15 at pin 1.
ALTERNATE: In some revisions at least, the enable pin for the fourth driver/channel is *SHARED* with the enable pin for the third channel ( assuming you wire them in the order XYZE, it means that your Z and E drivers share their enable line ).
DB15
Pin CNC
1 E-ENABLE
Note: The enable pin's are pulled high so if you do not drive them
all drivers are enabled by default.
DIP Switches
Current Setting 1 2 Decay Mode Settings 3 4 MicroStep Settings 5 6
100% ON ON FAST ON ON 1 ON ON
75% ON OFF 25% ON OFF 1/2 ON OFF
50% OFF ON 50% OFF ON 1/8 OFF ON
25% OFF OFF SLOW OFF OFF 1/16 OFF OFF
The currently recommended settings for the DIP switches are:
X & Y axis: 25% Current, Slow Decay Mode, No Microstepping ( ie use Microstepping value of 1 ) ie: OFF,OFF,OFF,OFF,ON,ON.
Z: To-be-determined. Currently we believe the required power setting may need to be higher than X& Ym, but we arent sure. No Microstepping. perhaps: OFF,ON,OFF,OFF,ON,ON.?
Extruder: To-be-determined. No Microstepping.
NOTES: You need to avoid microstepping unless you have the absolute latest firmware, because with *lots* of microstepping interrupts on all axes, you will get packet loss on the USB-Serial Host communications. For now, the fix is to avoid microstepping. It makes it easier to debug lost steps, etc anyway.
Signal waveform and timing:
The attached image seems to imply that there is a requirement to have the "step" pin pulled low while the direction pin undergoes a change. It also seems to imply that there should be a quiescient period before and after the change labeled "2C". A is the pulse width, B is the inter-pulse width, and 'C' is the required quiensent time before and after a direction change. The minimum values for A, B, and C are not known at this time, but may possibly be calculated experimentally. please update the wiki page if you have more information on this.
