Wood3d
Revision as of 16:50, 17 September 2014 by Snake233 (talk | contribs)
//identifies pages under construction. remove when the page is relatively stable.
WOOD3D
Release status: concept
An easy fabricable printer on small cnc's
CC-BY-NC-SA
Deltabot
Introduction
This printer is a redesigned one. The main aspect why i redesigned it is, that you can machine it on your small home cnc router. The motors and the electronics are mounted on the top, because of heat development. The six segments of the top assembly are the same like on the bottom. The spool is mounted on top. Access is granted at all sides of the printer. Easy height change. Closed loop belts for better mounting. A row of holes in the spool holder for diverse spools. simple adjusting of the endstops. hollow carbon fibre bars. Motormount is just with zip ties. An own developed effector. No vertikal extrusion profiles needed. The big effector should enable paste extruders.
Machined Parts
Videos
<videoflash type="youtube">5RUjISis6-M</videoflash>
technical details
Electronics Ramps1.4 common microswitch heatebed: no (pla recommended) extruder: bowden geared hotend: MK-V
Mechanics 12mm hardenend rod 700mm long - 6x GT2 belt and suitable pulleys pneufit push in fittings for bowden extruder PTFE Tube D6 - carbon fibre hollow tubes Ball joints - 12x Nema17 motor
