Wilson TS Bill of Materials
The parts list below is the default for Wilson TS, which uses all metric components and has a 210mm x 210mm x 200mm (XYZ) build volume.
There is an OpenOffice spreedsheet in the github repository which will assist in generating a BOM for other build volumes.
You can easily use other lengths of rods and extrusions if more convenient to source. I don't recommend trying to extend the Z axis up a lot though, because the stress on the lower frame mounts may become too much.
Also note that the Z axis lengths here were determined with my particular J-Head hot end, which sticks down about 40mm below the bottom of the extruder, and includes 3mm of glass on top of the heat bed.
Parts List
Mechanical parts
Printed Parts
All other parts
Everything Else | ||
NEMA17 Stepper motor | 5 | 48mm height, "high torque" |
Hot End (J Head) | 1 | |
MDF board (6mm thick) | 1 | 230mm by 230mm |
MK2, MK2a, etc Heat bed | 1 | |
Glass bed | 1 | 3mm borosilicate |
Controller (Mega/RAMPS, Rambo, etc | 1 | |
Endstop (limit) switch | 3 | |
LM8UU Linear bearing | 11 | |
608ZZ roller bearing | 3 | Used for extruder |
624 roller bearing | 2 | Used for Y and X idler ends |
5mm to 5mm shaft couplers | 2 | Can also use 3/16" ID vinyl tubing |
40mm x 40mm x 10mm fan | 1 | |
80mm x 80mm fan | 1 | |
Miniature zip ties | 20 | |
Extruder idler springs | 2 | High tension |
Bed leveling springs | 4 | Lower tension |
Power Supply | 1 | ATX supply with enough 12V amperage for your heat bed. |
M8 Hobbed bolt | 1 |
