Wilson TS Bill of Materials
Revision as of 13:48, 5 March 2014 by Mrice (talk | contribs) (Mechanical parts)
Introduction | Bill of materials | Assembly
The parts list below is the default for Wilson TS, which uses all metric components and has a ~200mm x 200mm x 200mm build volume.
There is an OpenOffice spreedsheet in the github repository which will assist in generating a BOM for other build volumes.
Parts List
Mechanical parts
Item Quantity Length / Note
2020 Extrusions (20mm square, t-slot)
Horizontal frame piece (top and bottom) 2 330mm
Y axis piece 2 380mm
M8 Smooth Rods
Y-Axis 2 380mm
Z-Axis 2 325mm
Threaded Rods
Belts & Pulleys
Y axis GT2 timing belt (w=6mm) 1 820mm
X axis GT2 timing belt (w=6mm) 1 930mm
GT2 pulley 2
Nuts & Bolts
M5 x 10mm machine screw 44
M5 hex nut 2
M5 t slot nut 44
M4 x 20mm machine screw 6
M4 hex nut 6
M3 x 8mm machine screw 1
M3 x 10mm machine screw 11
M3 x 14mm machine screw 18
M3 x 30mm machine screw 7
M3 x 60mm machine screw 2 50mm ok if your springs are short enough
M3 hex nut 20?
M3 lock nut 7
M8 x 20mm smooth rod or grub screw 1
Printed Parts
Printed Parts – Required
Z motor holder, left
Z motor holder, right
Z rod holder, left
Z rod holder, right
Printed Parts – Recommended
RAMPS Electronics/Fan frame mount 1 Wilson-ramps-mount.jpg
All other parts
Everything Else
NEMA17 Stepper motor 5
Hot End (J Head) 1
MDF board (6mm thick) 1 230mm by 230m
MK2 Heat bed 1
Glass bed 1 3mm borosilicate
Controller (Mega/RAMPS, Rambo, etc 1
Endstop (limit) switch 3
LM8UU Linear bearing 12
608ZZ roller bearing 4
624 roller bearing 2
5mm to 5mm shaft couplers 2 Can also use 3/16" ID vinyl tubing
40mm x 40mm x 10mm fan 1
80mm x 80mm fan 1
Miniature zip ties 20
Extruder idler springs 2 High tension
Bed leveling springs 4 Lower tension
Power Supply 1
