Wilson RS Bill of Materials
The parts list below is the default for Wilson RS, which uses all metric components and has a ~200mm x 200mm x 200mm build volume.
There is an OpenOffice spreedsheet in the github repository which will assist in generating a BOM for other build volumes.
Parts List
Mechanical Parts
Printed Parts
Printed Parts – Required | ||
Y end idler | 1 | |
Y end motor | 1 | |
Y belt holder | 1 | |
Frame bracket | 2 |
Printed Parts – Recommended | ||
RAMPS Electronics/Fan frame mount | 1 | |
Filament spool support | 1 | |
SMART display frame mount | 1 |
Other parts
Everything Else | ||
NEMA17 Stepper motor | 5 | |
Hot End (J Head) | 1 | |
MDF board (6mm thick) | 1 | 230mm by 230m |
MK2 Heat bed | 1 | |
Glass bed | 1 | 3mm borosilicate |
Controller (Mega/RAMPS, Rambo, etc | 1 | |
Endstop (limit) switch | 3 | |
LM8UU Linear bearing | 12 | |
608ZZ roller bearing | 4 | |
624 roller bearing | 2 | |
5mm to 5mm shaft couplers | 2 | Can also use 3/16" ID vinyl tubing |
40mm x 40mm x 10mm fan | 1 | |
80mm x 80mm fan | 1 | |
Miniature zip ties | 20 | |
Extruder idler springs | 2 | High tension |
Bed leveling springs | 4 | Lower tension |
Power Supply | 1 |
