Item |
Quantity |
Notes
2020 Aluminum extrusion, 500mm |
4
2020 Aluminum extrusion, 400mm |
4
2020 Aluminum extrusion, 330mm |
3
M10 Smooth Rod, 500mm |
2
M10 Smooth Rod, 370mm |
2
M10 Smooth Rod, 320mm |
2
8mm lead screw, 300mm |
2
GT2 timing belt, w=6mm |
2 meters
GT2 pulley |
2
M5 x 10mm machine screw |
55
M5 t slot nut |
55
M4 x 10mm machine screw |
4 |
These are used for the psu mounting bracket
M4 x 20mm machine screw |
4 |
For belt idlers and tensioners
M4 x 25mm machine screw |
4 |
These are used to mount the extruder to the X carriage
M4 hex nut |
6
M4 lock nut |
2 |
Use for idler bearing assemblies
M3 x 10mm machine screw |
12 |
Z and Y axis motor mounts
M3 x 14mm machine screw |
19 |
3 for X motor, 4 for extruder fan, 2 for lcd mount, 4 for lead screw nut mounts, 2 for ramps cooling fan, for for y table
M3 x 25mm machine screw |
6 |
3 for extruder stepper motor, 1 for fan duct to the extruder, 2 for tensioners
M3 x 30mm machine screw |
6 |
4 for print bed, 2 for hot end clamp / servo mount
M3 x 60mm machine screw |
2 |
These are used for the extruder
M3 hex nut |
22
M3 lock nut |
5 |
use locknuts for print bed mount and fan duct mount
M3 washer |
10 |
Need 4 for extruder springs, but have some handy if needed elsewhere
M2 x 16mm machine screw |
9 |
These and M2 nuts for mounting end stops, 1 for servo mount, and 2 for LM2596 mount
M2 hex nut |
9
