Wilson II BOM
Revision as of 21:40, 15 November 2015 by Mrice (talk | contribs)
Item Quantity
2020 Aluminum extrusion, 500mm 4
2020 Aluminum extrusion, 400mm 4
2020 Aluminum extrusion, 330mm 3
M10 Smooth Rod, 500mm 2
M10 Smooth Rod, 370mm 2
M10 Smooth Rod, 320mm 2
8mm lead screw, 300mm 2
Belts & Pulleys Y axis GT2 timing belt (w=6mm) 1 1030 X axis GT2 timing belt (w=6mm) 1 900 GT2 pulley 2 Want diameter 16-20mm Nuts & Bolts M5 x 10mm machine screw 55 M5 t slot nut 55 M4 x 10mm machine screw 4 These are used for the psu mounting bracket M4 x 20mm machine screw 4 For belt idlers and tensioners M4 x 25mm machine screw 4 These are used to mount the extruder to the X carriage M4 hex nut 6 M4 lock nut 2 Use for idler bearing assemblies M3 x 10mm machine screw 12 Z and Y axis motor mounts M3 x 14mm machine screw 19 3 for X motor, 4 for extruder fan, 2 for lcd mount, 4 for lead screw nut mounts, 2 for ramps cooling fan, for for y table M3 x 25mm machine screw 6 3 for extruder stepper motor, 1 for fan duct to the extruder, 2 for tensioners M3 x 30mm machine screw 6 4 for print bed, 2 for hot end clamp / servo mount M3 x 60mm machine screw 2 These are used for the extruder M3 hex nut 22 M3 lock nut 5 use locknuts for print bed mount and fan duct mount M3 washer 10 Need 4 for extruder springs, but have some handy if needed elsewhere M2 x 16mm machine screw 9 These and M2 nuts for mounting end stops, 1 for servo mount, and 2 for LM2596 mount M2 hex nut 9
