User:Powdermetal
Revision as of 17:37, 8 July 2016 by Powdermetal (talk | contribs)
Goto Cycloidal Extruder Drive
Release status: Experimental
Cycloidal gearbox for a lightweight & compact direct drive extruder
GPL
Intro
Running a delta printer with a Bowden-style type extruder, many people have been looking into alternatives for a more direct filament-feed response (especially when using flexible materials) while still keeping the dynamics of a lightweight effector system. There are a bunch of options out there and each one has it's specific strengths...
Project Target
  • Develop a lightweight, compact and powerful direct driven extruder for 3mm filament with a MK8 drive gear
  • Utilize a NEMA8/11/14-stepper for weight reasons
  • Minimize gearbox package through choosing a cycloidal drive system (gearbox ratio probably between 36:1 and 10:1)
  • Potentially setup an attractive alternative to the outphased NMB PG35L-048
Build v0.4
Objectives (see development history)
  • Improve overall robustness:
    • Avoid loosing steps while extruding manually from the printer controller
    • Stiffen the hotend clamp - v0.3 shows some visual flexing while extruding hard
    • Improve printability of parts (especially eccentric) and make the assembly process less tricky
  • Do some minor changes to the periphery
Design (see development history)
  • Gearbox ratio is changed to 16:1 -> no of teeth: 16, eccentricity: 0.8mm, radius: 16mm, roller radius: 1.6mm
  • Improve fit of centering bearing on motor shaft: Gain axial space by using bearings without shields
  • Make assembly process simpler by adding some axial clearances
  • Improve rigidity of hotend clamp by going back to the v0.2 concept
  • Add 3 connecting points for bolting the effector (M2 screws)
  • Replace the two idler springs with O-rings
  • Fix a minor bug in the v0.3 cycloidal curve equation
  • STEP-files of the assembly with detailed components and simplified geometry for the core parts (for simplifying mods): Media:CycloExtruder_v04.zip
BOM
Make & Assemble
  • Print the parts: 2 perimeters, 100% infill, layer height 0.1mm, use ABS/PETG, go slowly for the gears (15mm/sec or less)
  • Cleanup the gears for running smoothly before assembly - remove any blobs and strings carefully - take your time for precision later on
  • Tune the eccentric's bore to make it go gently (!) over the motor shaft and remove it gently again
  • Tune the eccentric outer faces so you can assemble the MR128 bearings
  • Press fit the MR128 bearings into the wobble gears, push them over the eccentric
  • Bolt the ring gear to the stepper motor
  • Mount the eccentric/wobble-gears over the motor shaft as follows:
    • Make the flat side of the D-shaft look to the right side
    • Align the marking dot of the lower gear exactly to the left side
    • Align the marking dot of the upper gear exactly to the right side
    • Make sure this position is kept, while the excenter and the excenter gears enter the ring gear
    • Push the eccentric onto the shaft until the motor shaft is 2.0mm above the eccentric's endface (pushing too far will make it to touch the stepper motor inside the gearbox...)
  • Add grease to the gears and to the holes for the pins
  • Press fit the 5mm shaft into the output carrier (using the shaft-mask tool for perpendicular assembly)
  • Press fit the 12 2mm dowel pins into the output carrier (the pin-mask tool and the pin-support-ring tool will help you)
  • Assemble all the rest
Test & Validate
  • Attached to an Azteeg X5, v1.1
  • Motor current: 0.45A, 32 microsteps, 9500 E-Steps (400 steps/rev * 32 microsteps / 21 mm/rev * i=16:1 -> 9.752 steps/mm)
  • Retract: 0.5mm, 10mm/sec
  • Speed: 80mm/sec, 0.4mm nozzle, 0.2mm layer height, material: PLA, temperature: 210°C
  • Testing: 10x10x5 blocks, Dia30 cylinders, some larger parts 1-3 hours each, in summary 12 hours printing
Results
  • Works well
  • No lost steps while extruding and retracting during prints, no more lost steps when manually extruding
  • Motor temperature: approx. 50°C
  • Slightly wavy surface appearance, seems to get better after some run-in period, still not matching my Bowden setup
  • No specific noise
  • No oozing/strings in retract situations
  • Eccentric is printable with 0.4mm nozzle without problems (smallest wall thickness 0.67mm)
  • Assembly is easier, but still demanding
  • v0.4 objectives met
Todo
  1. Continue testing - confirm durability
  2. There is potential for better surface appearance of printed parts - needs precision-machined gears & eccentric
  3. Review filament guiding
  4.  ?
Links
