ToyREP Buyers Guide
Revision as of 18:29, 5 August 2015 by Thorgal (talk | contribs) (Created page with "{| class="wikitable sortable" border="1" ! scope="col" class="unsortable" | Picture ! scope="col" | Quantity ! scope="col" | Description ! scope="col" class="unsortable" | Com...")
Picture Quantity Description Comments
ToyREP-PSU1.jpg 1 PSU Cover Chose PSU1.stl (111x78x36mm big PSU) or PSU2.stl (129x99x38mm big PSU)
1 1.8m Power Supply cable with plug cca 1.5-2mm long PC cable would be just fine - cut of the computer Euro connector, keep power socket plug.
1 200mm Dual Line cable Should be able to withstand at least 12V 4A, Insulation with two colours to distinguish +12V and -12V
1 Power supply switch (250V, 1A) Installation into panel with mounting hole 13x19mm
4 Ø6mmx25 Heat Shrink
1 3X13 Round-pan Wood Screw
1 Cable Tie
ToyREP-PCB1-1.jpg 1 PCB Mount Chose PCB1-1.stl for PSU1 or PCB2-1.stl PSU2.stl for PSU2
ToyREP-PCB1-2.jpg 1 PCB Mount Chose PCB1-2.stl for PSU1 or PCB2-2.stl PSU2.stl for PSU2
2 M8x255mm Threaded Rod Alternatively 265mm long for PSU2 and/or 125x125mm print area or 240mm for printer with 100x100mm print area and without PSU.
1 M8x245mm Threaded Rod Alternatively 265mm long for PSU2 and/or 125x125mm print area or 230mm for printer with 100x100mm print area and without PSU.
6 M8 Hex Nut
6 M8 Washer
3 M3X10 Countersunk Screw
ToyREP-Z1.jpg 1 Left Z Motor Mount
ToyREP-Z2.jpg 1 Right Z Motor Mount
2 28BYJ-48 Stepper Motor Length of wire c. 120mm and 180mm
2 Ø8x295mm Smooth Rod
8 M8 Hex Nut
38 M8 Washer Additional washer are used to set correct distance between plastic parts. The amount can vary.
1 M3x90mm Threaded Rod
4 M3 Hex Nut
1 M3 Washer
4 3X13 Round-pan Wood Screw
ToyREP-Y2.jpg 1 Rear Y Axis Bearing Mount
ToyREP-Leg.jpg 2 Y Frame Corner Leg
1 624ZZ Ball Bearing
2 M8x170mm Threaded Rod Alternatively 180mm long for PSU2 and/or 125x125mm print area or 155mm for printer with 100x100mm print area and without PSU.
12 M8 Hex Nut
12 M8 Washer
1 M4x20mm Round-pan Screw
1 M4 Hex Nut
3 M4 Washers
1 M6 Mudgard Washer
ToyREP-Y1.jpg 1 Front Y Axis Motor Mount
ToyREP-T2.5 Pulley.jpg 1 T2.5 Timing Belt Pulley
1 28BYJ-48 Stepper Motor Length of wire c. 250mm
1 Micro Switch Mounting holes Ø2.5mm 11mm apart, length of wire c. 300mm
12 M8 Hex Nut
12 M8 Washer
2 3X13 Round-pan Wood Screw
2 2.5X10 Round-pan Wood Screw
8 M8 Hex Nut
8 M8 Washer
ToyREP-Frog.jpg 1 Frog base
ToyREP-Frog 100.jpg 2 Frog extenders. Use Frog_100 for 100x100mm print area or Frog_125 for 125x125mm print area
4 LM8UU Bearing
4 M4 Hex Nut
4 M4x50 Countersunk Screws
4 M3 Nylock Nut
8 Cable Tie
2 Ø8x225mm Smooth Rod Alternatively 245mm long for PSU2 and/or 125x125mm print area or 220mm for printer with 100x100mm print area and without PSU.
1 T2.5x500mm Timing belt Alternatively 520mm long for PSU2 and/or 125x125mm print area or 470mm for printer with 100x100mm print area and without PSU.
ToyREP-Carriage.jpg 1 Frog base
ToyREP-X1.jpg 1 Left X Axis
ToyREP-X2.jpg 1 Right X Axis
ToyREP-ZMAX.jpg 2 Z Axis Top Bracing
ToyREP-Z Joint.jpg 2 Z Axis Motor Joint
1 28BYJ-48 Stepper Motor Length of wire c. 500mm
2 Micro Switch Mounting holes Ø2.5mm 11mm apart, length of wire c. 850mm
7 LM8UU Bearing
2 Ø8x245mm Smooth Rod Alternatively 255mm long for PSU2 and/or 125x125mm print area or 230mm for printer with 100x100mm print area and without PSU.
1 M8x255mm Threaded Rod Alternatively 265mm long for PSU2 and/or 125x125mm print area or 240mm for printer with 100x100mm print area and without PSU.
2 M5x250mm Threaded Rod
1 T2.5x480mm Timing belt Alternatively 500mm long for PSU2 and/or 125x125mm print area or 450mm for printer with 100x100mm print area and without PSU.
2 Ø8/5x20mm PVC Tube
4 M8 Hex Nut
4 M8 Washer
2 M5 Hex Nut
1 M4 Hex Nut
3 M4 Washers
1 M6 Mudgard Washer
4 M3x20mm Countersunk Screw
4 M3 Hex Nut
4 2.5X10 Round-pan Wood Screw
14 Cable Tie
ToyREP-Extruder Rev1.jpg 1 Extruder body
ToyREP-Idler.jpg 1 Extruder Idler
ToyREP-Gear.jpg 1 Big Gear With 36 Teeth
ToyREP-Pinion.jpg 1 Small Gear With 9 Teeth
ToyREP-Fan.jpg 1 Fan And Hotend Mount
1 28BYJ-48 Stepper Motor Length of wire c. 850mm
1 E3D Clone With 12V 40W ceramic heat cartridge and 100k Ohm thermistor, length of wire c. 950mm
1 40x40x10mm Fan Small 12V fan, length of wire c. 950mm
3 608ZZ Bearing
1 M8 Hobbed bolt for eg. Hyena hobbed bolt.
1 Ø8x15mm Smooth Rod
1 M8 Nylock Nut
4 M8 Washer
2 M4x50mm Round-pan Screw
2 M4 Hex Nut
4 M4 Washers
2 Ø7/5x15mm Spring
4 M3x35mm Round-pan Screw
2 M3x30mm Countersunk Screw
2 M3x25mm Countersunk Screw
4 M3x16mm Round-pan Screw
2 M3 Nylock Nut
1 M3 Hex Nut
4 M3x12 Hex Nut If long hex nut not available glue into each hole of fan mount two M3 nuts. Keep them apart.
7 M3 washer
10 Cable Tie
1 120x120x3mm Polycarbonate Plate Mounting holes in corners 105x105mm apart. Bigger bed is 145x145x3mm with mounting holes 130x130mm apart.
4 Ø7/5x15mm Spring
4 M3x25mm Countersunk Screw
8 M3 washer Eventually M4 Washers
