Skeinforge
Revision as of 11:29, 8 November 2008 by 89.240.74.30 (talk) (New page: ===Skeinforge & Skeinview=== Skeinforge is script used to output GCode from Art of Illusion. (it was preiviously called Threadforge and Export Slices before that) it is available at: [htt...)
Skeinforge is script used to output GCode from Art of Illusion. (it was preiviously called Threadforge and Export Slices before that) it is available at: Skeinforge
To use it, put the file into the Art of Illusion "tools" folder in the "scripts" folder. Then turn the shape you wish to output into a triangle mesh, select it and choose Skeinforge from the Scripts menu in the Tools folder, then click OK.
Below is a gcode excerpt produced using Skeinforge. Below that is the excerpt after comments were added by Skeinview, a related gcode viewer and analyzer, which is at Skeinview
( GCode generated by March 29,2007 Skeinforge ) ( Extruder Initialization ) M100 P210 M103 M104 P145.0 M105 M106 M108 P0.8 G21 G90 G28 ( Extruder Movement ) ( Extruder paths for layer 0 of Hollow Square ) M101 G1 X-2.935 Y1.84 Z0.376 F600.0 .. many lines of gcode .. G1 X-4.931 Y-2.349 Z1.124 F600.0 M103 ( Extruder Shut Down ) M103 M104 P0 M107
Below that is the same excerpt after comments were added by Skeinview, a related gcode viewer and analyzer, which is at Skeinview
( GCode generated by March 29,2007 Skeinforge ) ( Extruder Initialization ) ( Set extruder speed to 210.0. ) M100 P210 ( Turn extruder off. ) M103 ( Set temperature to 145.0 C. ) M104 P145.0 ( Custom code for temperature reading. ) M105 ( Turn fan on. ) M106 ( Set extrusion diameter to 0.8 mm. ) M108 P0.8 ( Set units to mm. ) G21 ( Set positioning to absolute. ) G90 ( Start at home. ) G28 ( Extruder Movement ) ( Extruder paths for layer 0 of Hollow Square ) ( Turn extruder on. ) M101 ( Linear move to Vec3: -2.935, 1.84, 0.376. ) G1 X-2.935 Y1.84 Z0.376 F600.0 .. many lines of gcode .. ( Linear move to Vec3: -4.931, -2.349, 1.124. ) G1 X-4.931 Y-2.349 Z1.124 F600.0 ( Turn extruder off. ) M103 ( Extruder Shut Down ) ( Turn extruder off. ) M103 ( Set temperature to 0.0 C. ) M104 P0 ( Turn fan off. ) M107
