SRJ
Revision as of 21:09, 14 October 2016 by Eric X (talk | contribs) (Video)
SRJ Opensource 3d printer
Release status: Working
An Opensource FDM 3d printer.
Introduction
The SRJ-I is an affordable, accurate, stable RepRap 3d printer.
All of it's parts are metal, so it's structrue is very strong.
Overview
  • A rigid anodized aluminium profile frame that withstands all kind of transportations.
  • All electronics are integrated, power supply, electronics, and the LCD display are taking as small place as necessary .
  • Wiring is premade, you won't need to solder, there are just plugs and screw terminals. Most wires are protected in a sleeve.
  • The heatbed is fixed with three thumbwheels, leveling is done within less than a minute.prominent.
  • The Borosilicate glass make your printing platform flat enough, so it improves the printing quality
  • We added a full metal extruder that can print everything that can be melted up to 300°C. Flexible materials too, and no melted filament leak.
  • Improved temperature control takes care of stable temperatures from 0 to 300°C.
Features
  • Print Technology:Fused Deposition Modeling.
  • Build volume:245*160*210mm.
  • Layer Resolution:0.1mm.
  • Filament Diameter:1.75mm.
  • Nozzle Diameter:0.4mm.
  • Heated Bed:24V/100W(resistor:4.5~5.5Ω)
  • Build Surface:Borosilicate glass.
  • Stepper Motors:1.8° step angle with 1/16 micro-stepping.
  • Power supply:DC 24V/360W.
  • Product Weight:15KG.
  • Product Dimensions:44L * 35W * 46H cm.
Pictures
MODELS
Important Considerations
Electronics
Video
[1]
Relevant Forum Threads
Related Wiki Pages
