RepRap Version II "Mendel"
This section of the RepRap documentation is about building and using RepRap Version II "Mendel". It is under construction.
Instructions
Mendel Specifications
' | UK metric | US imperial |
Manufacturer | RepRap | |
Model | Mendel | |
Technology | FFF (Fused Filament Fabrication)/Thermoplastic extrusion | |
Price | £395.00 | $630 |
Annual Service Cost | Occasional oiling = £5 | Occasional oiling = $10 |
Size & Wt. | 500 mm (W) x 400 mm (D) x 360 mm (H) | 20” (W) x 16” (D) x 14” (H) |
Build Envelope | 200 mm (W) x 200 mm (D) x 140 mm (H) | 8” (W) x 8” (D) x 5.5” (H) |
Materials | PLA, HDPE, ABS & more. Uses ø 3 mm (0.118”) filament. | |
Material Cost | PLA: $?/lb, HDPE: $7/lb, ABS: $10/lb | PLA: $?/lb, HDPE: $7/lb, ABS: $10/lb |
Speed | fair | |
Accuracy | Resolution of nozzle 0.5mm, 2mm min. feature size, 0.1mm positioning accuracy, layer thk 0.5mm | Resolution of nozzle 0.0196”, 0.0787” min. feature size, 0.0039 positioning accuracy, layer thk 0.0196” |
Finish | fair | |
Mendel vs. Darwin
Mendel is the latest generation RepRap machine. Mendel supercedes the first version, which we call Darwin. For RepRap Version I "Darwin" instructions follow this link.
Mendel has the following key improvements over Darwin:
- Bigger print area, smaller machine footprint
- Improved constraint on the z-axis to eliminate jamming
- Better axis efficiency
- Simpler assembly
- Capacity of tool changing
This video illustrates these improvements:
<videoflash type="vimeo">6983001|640|480</videoflash>
For a numerical comparison see this blog post.
