RamboLCD
Revision as of 20:29, 25 November 2012 by Johnoly99 (talk | contribs) (Assembly)
RAMBoLCD
Release status: Experimental
Hook up an LCD display to RAMBo
GPL
Introduction
This page is reserved for documentation relating to adapting popular LCD controllers such as the reprapdiscount.com RAMPS LCD controller, to work on the RAMBo boards by UltiMachine. You will find all the instructions needed here to modify the cables, firmware and more to get your LCD controller working.
PDF instructions
Attached is a document which details how to connect the reprapdiscount LCD/SD to the Rambo board. Eventually I'll fill put this info straight into the wiki rather than a PDF, but this should work for the time being.
Media:Rambo-LCD.pdf
BOM
RAMBo board (obvious)
LCD controller (reprapdiscount.com used in the instructions here)
2x4 female header cable between RAMBo SPI connection and reprapdiscount.com LCD shield
2X8 female header cable between RAMBo EXT headers and reprapdisount.com shield
Assembly
Step 1
Follow the instructions in the PDF and make the cable connections as follows
Step 2
Adjust your Arduino IDE boards config as shown in the PDF
Step 3
Modify your firmware files as shown in the PDF in both fastIO and pins.h, as well as editing your configuration.h file
