PortaPrusa
Revision as of 21:29, 11 May 2014 by Cubedparadox (talk | contribs) (Created page with "{{Languages|PortaPrusa}} {{RepRapNavigation|name=PortaPrusa}} {{Development |name = PortaPrusa |status = in development |image = N/A |description = A super compact foldable ...")
PortaPrusa Documentation
PortaPrusa
Release status: in development
A super compact foldable 3d printer.
N/A
Introduction
The PortaPrusa is a foldable briefcase 3d printer based heavily off of the design of the Prusa i3. The goal of this printer was to create a printer that could collapse into the smallest possible volume while still maintaining an all-in-one structure, as well as being robust and aesthetically pleasing.
Specifications
Plastic Parts 31
Non Printed Parts a lot
Cost ?
Controller Electronics Almost all RepRap
Printing Size 200 x 200 x 200
Motors 5 x NEMA 17 Stepper
Frame Material ?mm Wood
Frame Manufacture Laser Cutter
Overall Size (Folded) ?
Overall Size (Unfolded) ?
Development
The development of the PortaPrusa is hosted on github: ___
Printed Parts
The [Github repository] for the PortaPrusa contains all of the STLs you need in order to make the printer. In addition, it also contains the source blend files.
The following is a list of what needs to be printed:
Quantity STL file Comments Picture
2 Z-Top.stl
1 Z-Bottom-Large.stl Allows clearance for X-axis motor
1 Z-Bottom-Small.stl
1 X-Big.stl Holds Motor
1 X-Small.stl
1 Extruder-Main.stl
1 Extruder-Arm.stl
1 Extruder-Plug.stl Retaining plug for bearing
1 Extruder-Clamp.stl Clamps Belt
4 M8-Mount.stl Retaining block for m8 rod
4 M4-Mount.stl Retaining block for m4 rod
1 Y-Motor.stl
1 Y-Idle.stl
2 Bed-Slide.stl
1 Bed-BeltMount.stl Top piece of belt clamp
2 Bed-Clamp.stl
2 Box-Pivot.stl
2 Drive-Gear.stl
2 Idle-Gear.stl
Laser Cut Parts
Quantity Description Comments
--- ?mm Wood ---
1 BottomPanel.dxf The big sheet
1 TopPanel.dxf The other big sheet
2 SidePlate.dxf Sides of box
1 TopPlate.dxf Top of box
1 BottomPlate.dxf Bottom of box
--- Acrylic ---
1 bedMount.dxf Goes under heated bed
Non-Printed Parts
Fasteners
 ? M3 nut
 ? M3 bolt ?
2 M5 nut For Z-Drive
2 M4 bolt For Pivot
2 M4 nut
Bearings
11 LM8UU (Asia) or LME8UU (US, Europe) linear bearings OR If using linear bearings, don't cut costs here. Cheap ones can damage the smooth rods.
8mmx25mm pla bushings
2 M4 linear bearings These will allow the box to slide shut.
5 Bearings 4X10X4
Rods
2 320mm 8mm smooth rod X axis
2 340mm 8mm smooth rod Y axis
2 350mm 8mm smooth rod Z axis
2 230mm 4mm smooth rod box slide
2 320mm M5 threaded rod z drive
1 710mm GT2 toothed belt Y axis
1 790mm GT2 toothed belt X axis
Other
2 1.5cm vinyl tubing, 6.35mm OD 4.32mm ID (3cm total) Used to attach motors to the Z axis threaded rods. Can be found at most hardware stores, typically used in toilets to connect refill tube to outlet.
1 Glass surface For print bed.
1 7mm 1.5cm compression spring Used to tension extruder.
2 Hinges Small hinges to hold cover panel on box
2 Clasps You need to keep this thing shut somehow.
Electronics
Stepper Motors
The PortaPrusa uses 5 NEMA17 stepper motors. Two of these motors, the Z axis motors, are connected to the same stepper driver of the electronics, which are typically wired in parallel but some builders wire them in series so that each motor gets the same amps (in case the resistances are not exactly the same).
About any RepRap controller works for the PortaPrusa. Required features: 4 stepper drivers, 1 thermistor input and 1 heater output for the extruder and another thermistor/heater pair for the heated bed. Choosing the best one for your printer is mostly a matter of taste. For this build, I used a printrboard deviant. You will need a compact power supply unit (PSU), like a laptop charger. Also remember that some electronics (RAMPS first and foremost) need an Arduino as well.
Extruder
The PortaPrusa supports a couple different extruders. Right now, these are:
J-Head ?
Heated Bed
The PortaPrusa will support any 200mm heated build platform. I use the Mk2 Heated Bed.
