Pololu stepper driver board
Revision as of 00:37, 12 December 2012 by BradDudenhoffer (talk | contribs) (Upgrades)
Stepper driver for RAMPS, Sanguinololu, Gen7
Commercial
Please note: Pololu stepper driver boards has 0.05 ohm sense resistors instead of StepStick 0.2 ohm.
List of Boards
Pololu driver boards (8+8 pins):
Pololu driver boards with Voltage Regulators (longer boards - 8+14 pins):
As user Nophead has pointed out, that Pololu driver is a nice design, but with one big shortcoming: it will run hot, and is difficult to cool because it's so small. So what I've done is to design the electronics in such a way that they both perform their function and act as a physical duct for the flow from a fan to direct their own cooling. A happy side-effect of this is that the resulting PCBs are very simple, and can be made single-sided without any thin tracks. That is is why RepRap itself can make them. We must walk before we can run... an another way to improve heat dissipation is the use of small heat sink, unfortunately the small adhesive pad are not so adhesive.... so the use of some thermal conductive glue make the thing easier (like this one, in french www.pc-look.com/boutik/63648.html but if you google: Arctic Silver - Arctic Alumina™ Thermal Adhesive you will find it or equivalent)
Alternatives
Tuning motor current
Per the A4988 datasheet [[1]], the calculation for the maximum trip current is:
 I_TripMax= Vref/(8*Rs)
With Pololus, the sensing resistors are Rs=0.05 ohm, so a Vref of 0.4 should produce a maximum current of 0.4/(8*0.05)=1A.
As another example, aiming for 50% temperature rise on 1A rated steppers by using max 0.7A, so rearrange it as:
 Vref = I_TripMax * 8 * Rs or
 Vref = 0.7 * 8 * 0.05 = 0.280V
With a measured Vref of 0.273V, I should expect 0.6825A, and I measured the current through one coil as 0.486A in full step mode, which should be 0.7071 of the full trip current, or I_TripMax= 0.486/0.7071= 0.687A, which seems close enough.
The Vref signal is accessible as the "VREF" pin on the carriers with voltage regulators, as the through-hole via on the carriers without, and also as the wiper on the trim pot itself on both carriers.
example of a v-ref checking, + probe on the turnpot and - on a ground pin
Note : for StepStick, the Rs=0.2 ohm, so you'd get 4 times the Vref at the same current.
The maths in full
For repraps, logic supply voltage (VDD) is 5V. For Pololu driver boards, the trimpot is 100kohm, trimpot resistor R5 is 20kohm, sense resistors R7 and R8 are 0.05ohm
VREF max = (TrimpotMaxR/(TrimpotMaXR+R5)) x VDD = (100,000 / (100,000 + 20,000)) * 5 = 4.16V
ITripMAX (effectively max motor current) = VREF / ( 8 x Sense_resistor) = 4.16 / ( 8 * 0.05 ) = 10.4A
To calculate amps from measured VREF: A = VREF / 0.4
To calculate VREF required for a target current: VREF = A * 0.4
Heat Consideration
The way the IC is designed, it wicks heat much better thru the large pad on the underside than it does through the outside of the packaging. This means the heatsink is not actually in the ideal place to wick heat away, and the quality of the solder job underneath is extra important. On some chinese knockoffs (white board and the pot has no built in stop) I notice they over heat and go into thermal shut down way before a real pololu board, even with a heat sink and fan. This could possibly be improved by re-flowing the solder on a hot plate, but I have not tried this as they are my backups. Pololu also offers a "black Edition" board which has extra copper in the PCB to help wick heat away from the IC and keep it cool. This is said to add on an extra .2 amps that can be maintained without heat sinking. Also using the same logic, it is more effective to blow cooling air under the board rather than over it, and brilliant design work on the RAMPS boards allows this quite easily.
Upgrades
Replace this resistor
By replacing 1 resistor on the board, the reference voltage becomes much easier to set. The resistor in question is to the left of the vref pot, if the pot is considered the top of the board.
The voltage divider and pot are poorly selected for the currents used. Since the board uses a 10k pot and 20k resistor to set the vref, the effective range is 0-1.7 volts, or 0-4.2 amps! Since the IC itself is only good to 2 amp max with perfect heat dissipation this does not make sense and makes it much harder to set the ref voltage since at 1/4 turn you have maxed out your driver. Since the resistor is the easiest to change, you simply need to drop in a 51K ohm resistor. Now the max current is 2.05 A with vRef = .82V. any resistor in a 0603 SMD packagingin will do. Personally I used a 68k ohm because I let someone else do the math for me, and I see thermal shutdown before I even hit 1 A, even w/ a heatsink and fan on these cheap chinese drivers so it makes no sense anyways. This limits me to 1.6 amp.
mouser PN : 311-51KCRCT-ND
See also
