P3Steel Vitamins
Vitamins
In RepRap jargon, a vitamin (also called an "imported part" or "non-printed part") is anything that you need to make a RepRap, which a RepRap cannot itself make.
Lasecut parts
P3Steel frame is mainly built from lasercut steel. CAD Drawings are available from GitHub and author's page on Thingiverse.
P3Steel V1.2 | P3Steel V2.0 |
Has 3 Bearings on Y Carriage and 4 point heated bed levelling system. | Has 4 Bearings on Y Carriage and 3 or 4 point heated bed levelling system. |
Mechanical Parts
Bearings, pulleys, timing belt
Rods
Threaded rods
Only 2 M5 threaded rods are needed:
- 2x Threaded rod M5x295 mm
Smooth rods
6 Smooth rods are needed of the following sizes:
- 2x Ø8x375 mm for X-Axis
- 2x Ø8x341 mm for Y-Axis
- 2x Ø8x320 mm for Z-Axis
Electronics
Image | Part | Quantity | Unit price | Total cost | Commentaries |
Arduino Mega 2560 board (or compatible) | 1 | -- | -- | The printer's "brain". | |
RAMPS 1.4 board | 1 | -- | -- | Interface betwen the arduino board and the hardware. | |
Stepper motor drivers. | 4 | -- | -- | Drive the motors | |
Mechanical endstops. | 3 | -- | -- | Tell the software when the carriage has reached the home position. Can be replaced with optical or magnetic sensors. | |
Smart LCD | 1(Optional) | -- | -- | Run your RAMPS without a computer just with a SD card and Gcode files. | |
Power supply. | 1 | -- | -- | Min power 16A, Recommended 30A |
