Open source hardware
Revision as of 10:14, 29 June 2010 by ErikDeBruijn (talk | contribs) (First draft on openness of hardware)
To a large extent, the RepRap project is successful because it is open. Openness can be seen as an enabler of collaboration among the growing group of volunteers.
Openness is considered to be many things, it generally has positive connotations, but there is no agreed upon definition. Regardless of the exact definition you choose, openness can be influenced by a series of mechanisms such as norms (principle, standards and guidelines). The principles and standards can be legal or non-legal and may be implemented in concrete rules. Things like cultural norms and licenses (a legal tool) can affect behavior and in turn affect the level of openness.
Open source has a more constrained meaning than the subject that is licensed, in principle it could be applied to software, hardware, documentation and other creative works. The typical open source development process is a specific type of development that is frequently found in software development projects. While there is a lot known about open source software and its development, relatively little research is done about open source "hardware" and how it is or could be developed.
Open source beyond software
Formally, for software to be called open source it has to conform to the Open Source Definition as outlined by the Open Source Initiative. Most notably, the definition implies that software has a license that permits modification, and must requires free redistribution of the software under the same license. The licenses compatible with the Open Source Definition are mostly based in copyright law since this type of intellectual property law is most applicable to software. Yet this definition does not lend itself well to also cover physical product licenses.
In the context of designs of open hardware with it's accompanying software and documentation, it is important differentiate between implementation and design. Open source licenses are mostly based in copyright law, which is about:
  • creative works
  • only implementation can be copyrighted (this rules out copyrighting a design, idea or working principle)
  • there has to be a record of it (it cannot be just in your head)
More information:
