NEMA 14 Stepper motor
Revision as of 04:36, 14 June 2014 by XoanSampaiño (talk | contribs) (Suppliers: Fix link)
Vitamin
A NEMA 14 sized stepper motor.
Wikipedia Stepper motor
A NEMA 14 stepper motor is a stepper motor with a 1.4 x 1.4 inch (35.6 x 35.6 mm) faceplate. Its size is not an indication of its power. The NEMA 14 is a smaller and neater motor that was used on the Mendel prototype.
Suppliers
Below is a non-exhaustive list of possible motors and suppliers.
You are welcome to add information on a stepper motor/vendor you encounter, but please add only steppers which were tested to actually work on some printer.
Manufacturer Model Holding torque Rated voltage Shaft Step angle Motor length Additional notes Vendor (shipping location)
He3D 14HY-35 13.7 N·cm double 2.7 V Ø 5 mm 1.8° 34 mm Used in Huxley. He3D (CN)
RobotDigg 14HY0006 and 14HY0007 9N.cm or 15N.cm N·cm 2.3 or 4.6 V Ø 5 mm single 1.8° 34 mm Used in Huxley. RobotDigg (CN)
SOYO SY35ST36-1004A 13.7 N·cm single 2.7 V Ø 5 mm 1.8° 36 mm Used in mendel prototype. Pololu (US)
Paoparts (FR)
Zapp (UK)
SOYO SY35ST36-1004B 13.7 N·cm double 2.7 V Ø 5 mm 1.8° 36 mm Same as SY35ST36-1004A, but double shaft. Zapp (UK)
Thingibox TB35HT36-1004AC 13.7 N·cm single 2.7 V Ø 5 mm 1.8° 36 mm RepRap Huxley. 70cm length cable. 4-wire crimped connector compatible with the vast majority of electronics, from RAMPS and Sanguinololu to Megatronics. Thingibox (ES)
Thingibox TB35HT36-1004BC 13.7 N·cm double 2.7 V Ø 5 mm 1.8° 36 mm RepRap Huxley. 70cm length cable. 4-wire crimped connector compatible with the vast majority of electronics, from RAMPS and Sanguinololu to Megatronics. Thingibox (ES)
Wantai 35BYG304
(also here)
12.3 N·cm 3.5 V Ø 5 mm 1.8° 28 mm Less holding torque than recommended, but has been used successfully (in a FoldaRap indie build [1]) Active Robots (UK)
External References
