Mix g1
Revision as of 06:34, 4 September 2012 by Jing.guo (talk | contribs)
About Mix G1
The design of Mix G1 is based on Wallace. The main advantage is the mechanical structure, which is easy to understand, build, and does not need much calibration . Mix G1 has one of the smallest nozzle size(0.34mm) that results great printing quality once you have it running. The printing speed can go up to 150mm/s for infill, and the layer hight is as thin as 0.17mm(can't even see the layers). You can check the picture of printed objects at http://blog.mixshop.com/tagged/mix-g1-printing.
Bill of material
Printed Parts
2x Z Holders
STL File
2x Pulley
STL File
4x Plate Base Connector
STL File
3x Power Supply Hook
STL File
4x X Holder
STL File
2x Base Part 1
STL File
2x Base part 2
STL File
1x X Motor Holder
STL File
1x X Motor Holder 2
STL File
1x Y Motor Holder
STL File
2x Z Top
STL File
4x Belt Clamp
File
3x Endstop Holder
STL File
Assembly Videos
Part 1
<videoflash>vE5kr5HGK6c</videoflash>
Bill of Material for video 1
6
300 M8 Thread Rod
8
LM8UU Linear Bearing
18
M8 Nut
16
M8 Wahser
2
Base Part 1 (*)
2
Base Part 2 (*)
4
Laser Cut footer (**) (version 1)
Note: It's replaced by "Base" in version 2
1
Power plug
1
Power switch
2
M3x16
37
M3 Nut
74
M3 Washer
5
NEMA 17
8
M3x10
6
M3x20
2
623 Ball Bearing
3
M3x6
2
Pulley (*)
4
M3x40
2
285mm Smooth Bar for Y-Axis
4
Plate Base Connector (*)
1
MDF Laser cut base (**)
1
400mm T5 Belt
6
Belt Clamp - Laser Cut (**) [Can be Printed Part "Belt Clamp(*)"]
20
M3x25
4
X Holder(**)
4
Z-Holders (*)
2
608 Ball Bearing
2
Z-Top (*)
2
390mm Smooth Bar
1
Assembly Extruder (Check Mix G1 extruder Assembly Video)
1
M4x30
2
M4 Fender Washer
3
M4 Washer
1
M4 Nut
1
X Motor Holder 2 (*)
1
X Motor Holder 1 (*)
1
800mm T5 Belt
Part 2
<videoflash>AbTtCrYo-xI</videoflash>
Part 3
<videoflash>ck9F2kqvPQY</videoflash>
