Mix g1
Introduction
About Mix G1:
The design of Mix G1 is based on Wallace. The main advantage is the mechanical structure, which is easy to understand, build, and does not need much calibration . Mix G1 has one of the smallest nozzle size(0.34mm) that results great printing quality once you have it running. The printing speed can go up to 150mm/s for infill, and the layer hight is as thin as 0.17mm(can't even see the layers). You can check the picture of printed objects at http://blog.mixshop.com/tagged/mix-g1-printing.
Bill of material:
Printed Parts
Assembly Videos
Part 1
<videoflash>vE5kr5HGK6c</videoflash>
Bill of Material for video 1 |
6 |
300 M8 Thread Rod |
8 |
LM8UU Linear Bearing |
18 |
M8 Nut |
16 |
M8 Wahser |
2 |
Base Part 1 (*) |
2 |
Base Part 2 (*) |
4 |
Laser Cut footer (**) (version 1) |
1 |
Power plug |
1 |
Power switch |
2 |
M3x16 |
37 |
M3 Nut |
74 |
M3 Washer |
5 |
NEMA 17 |
8 |
M3x10 |
6 |
M3x20 |
2 |
623 Ball Bearing |
3 |
M3x6 |
2 |
Pulley (*) |
4 |
M3x40 |
2 |
285mm Smooth Bar for Y-Axis |
4 |
Plate Base Connector (*) |
1 |
MDF Laser cut base (**) |
1 |
400mm T5 Belt |
6 |
Belt Clamp - Laser Cut (**) [Can be Printed Part "Belt Clamp(*)"] |
20 |
M3x25 |
4 |
X Holder(**) |
4 |
Z-Holders (*) |
2 |
608 Ball Bearing |
2 |
Z-Top (*) |
2 |
390mm Smooth Bar |
1 |
Assembly Extruder (Check Mix G1 extruder Assembly Video) |
1 |
M4x30 |
2 |
M4 Fender Washer |
3 |
M4 Washer |
1 |
M4 Nut |
1 |
X Motor Holder 2 (*) |
1 |
X Motor Holder 1 (*) |
1 |
800mm T5 Belt |
Part 2
<videoflash>AbTtCrYo-xI</videoflash>
Part 3
<videoflash>ck9F2kqvPQY</videoflash>
