Mix g1
Revision as of 06:29, 4 September 2012 by Jing.guo (talk | contribs)
About Mix G1:
The design of Mix G1 is based on Wallace. The main advantage is the mechanical structure, which is easy to understand, build, and does not need much calibration . Mix G1 has one of the smallest nozzle size(0.34mm) that results great printing quality once you have it running. The printing speed can go up to 150mm/s for infill, and the layer hight is as thin as 0.17mm(can't even see the layers). You can check the picture of printed objects at http://blog.mixshop.com/tagged/mix-g1-printing.
Bill of material:
Printed Parts
2x Z Holders
STL File
2x Pulley
STL File
4x Plate Base Connector
STL File
3x Power Supply Hook
STL File
4x X Holder
STL File
2x Base Part 1
STL File
2x Base part 2
STL File
1x X Motor Holder
STL File
1x X Motor Holder 2
STL File
1x Y Motor Holder
STL File
2x Z Top
STL File
4x Belt Clamp
File
3x Endstop Holder
STL File
Assembly Videos
Part 1
<videoflash>vE5kr5HGK6c</videoflash>
Bill of Material for video 1
6
300 M8 Thread Rod
8
LM8UU Linear Bearing
18
M8 Nut
16
M8 Wahser
2
Base Part 1 (*)
2
Base Part 2 (*)
4
Laser Cut footer (**) (version 1)
Note: It's replaced by "Base" in version 2
1
Power plug
1
Power switch
2
M3x16
37
M3 Nut
74
M3 Washer
5
NEMA 17
8
M3x10
6
M3x20
2
623 Ball Bearing
3
M3x6
2
Pulley (*)
4
M3x40
2
285mm Smooth Bar for Y-Axis
4
Plate Base Connector (*)
1
MDF Laser cut base (**)
1
400mm T5 Belt
6
Belt Clamp - Laser Cut (**) [Can be Printed Part "Belt Clamp(*)"]
20
M3x25
4
X Holder(**)
4
Z-Holders (*)
2
608 Ball Bearing
2
Z-Top (*)
2
390mm Smooth Bar
1
Assembly Extruder (Check Mix G1 extruder Assembly Video)
1
M4x30
2
M4 Fender Washer
3
M4 Washer
1
M4 Nut
1
X Motor Holder 2 (*)
1
X Motor Holder 1 (*)
1
800mm T5 Belt
Part 2
<videoflash>AbTtCrYo-xI</videoflash>
Part 3
<videoflash>ck9F2kqvPQY</videoflash>
