Mix g1
About Mix G1:
The design of Mix G1 is based on Wallace. The main advantage is the mechanical structure, which is easy to understand, build, and does not need much calibration . Mix G1 has one of the smallest nozzle size(0.34mm) that results great printing quality once you have it running. The printing speed can go up to 150mm/s for infill, and the layer hight is as thin as 0.17mm(can't even see the layers). You can check the picture of printed objects at http://http://blog.mixshop.com/tagged/mix-g1-printing.
Bill of material:
Printed Parts
