Mendel90
Revision as of 06:37, 4 March 2012 by AdrianKelly (talk | contribs) (Added Mendel90)
Mendel90
Release status: Experimental
A Mendel with flat sheets at 90 degree angles
Mendel90 is being designed by Nophead to replace many of the threaded rods and printed parts of the [Prusa Mendel] with flat sheets, either MDF or Acrylic. It's advantages compared to the Prusa Mendel are:
  • Stiffer, especially in the X Direction, where it is most important
  • Much less calibration and jigging required; if your holes are in the right places, your rods will be parallel
  • Can be drilled with a paper template to make sure all holes are perfect
  • Sheets are usually straighter and flatter than rods, as they are thicker and much wider
  • All the OpenSCAD files are fully parametric; you can set all the parts to whatever sizes you want
  • Everything is mounted on one of two planes, so it's all flat
  • Frame is held together throughout the machine, instead of just at the corners, so no warping
  • Open design, allowing it to be worked on easier and mostly dissasembled without falling apart
  • Z axis motors are at the bottom, so that the couplings don't need to support the weight of the X axis
    • This means the Z couplings can be smaller, and therefore Z smooth rods closer to the threaded rods, increasing stiffness
    • The center of balance is also lower, making it more stable
  • Less printed parts, so it can be printed easier and faster
  • Parts are ribbed to maintain strength and decrease print time
  • Ribbon cables are used to prevent cable tangling and friction
  • Rectangular, so it can be shipped and put in Heated Build Chambers easier.
See Also
Category:Development
