MKS GEN
Release status: Working
Description | Single board solution, Remix of Arduino mega2560 and RAMPS1.4
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Summary
MKS Gen is a feature rich all-in-one electronics solution for Reprap and other CNC devices.
It features an onboard ATmega2560. Its five motor outputs are powered by Pololu pin compatible stepper drivers.
The board features a developer friendly expansion port supporting giving access the same as Ramps1.4.
MKS Gen is designed to be flexible in the user's power source availability, allowing any power supply from 12V-24V.
Safety Tip
Caution Once you start putting electricity into your RepRap - even at just 12 volts - you have to take basic, common sense precautions to avoid fires. |
MKS Gen USB Driver
MKS Gen USB Driver Chip FT232RL,you can get files from ftdichip to setup driver File:Ftdi-x86.zip.
Features
- Arduino MEGA compatible Atmega2560 and FT232 processors are compatible with all RAMPS class firmware
- Firmware can use the same configuration as ramps1.4
- Easy DISPLAY + SD-CARD connector,RepRapDiscount SmartController compatible pin header on board
- All extra pins broken out the same as ramps1.4(AUX-1,AUX-2,AUX-3,Servos1)
- 3x temperature ADC connectors for thermistors
- up to 5 motor driver with easy micro stepping setup (micro switches)
- 4x PWM capable power mosfet outputs with voltage selector for MainPower.(Bed,Extruder0,Extruder1, Fans)
- 4 layers PCB, optimize heat dissipation.
- 6x end stop connectors with power supply Xmin/Xmax/Ymin/Ymax/Zmin/Zmax
- 3* 5V output, 3* 12V-24V output interface.
- Recoverable fuse for short-circuit protection.
Motor Driver
Microstepping
MKS Gen contain a row of 3 jumpers.
with DRV8825
1 | 2 | 3 | step mode |
0 | 0 | 0 | Full step (2-phase excitation) with 71% current |
1 | 0 | 0 | 1/2 step (1-2 phase excitation) |
0 | 1 | 0 | 1/4 step (W1-2 phase excitation) |
1 | 1 | 0 | 8 microsteps / step |
0 | 0 | 1 | 16 microsteps / step |
1 | 0 | 1 | 32 microsteps / step |
0 | 1 | 1 | 32 microsteps / step |
1 | 1 | 1 | 32 microsteps / step |
with A4988
0 | 0 | 0 | Full step |
1 | 0 | 0 | 1/2 step |
0 | 1 | 0 | 1/4 step |
1 | 1 | 1 | 16 microsteps / step |
