Links Into Hangprinter v3 Build Video
Revision as of 09:25, 16 January 2018 by Tobben (talk | contribs)
On Dec 13-15, 2017, tobben and Tom made a live stream in 4 parts on Youtube, where they built and debugged a Hangprinter v3. The videos are very long, so this wiki page is created as a "table of contents". Help out and fill in if you watch the videos: Part 1, Part 2, Part 3, Part 4.
Part 1
1m38s: Start
2m52s: Start of mover build
5m24s: Snap mover into place
14m22s: Cracking sounds in printed mover parts. New versions of those parts do not rely on flex anymore.
17m18s: Orientation of extruder motor.
19m10s: "I want to use a naked mover to make markings on the ceiling plate."
24m44s: D-linerollers use bowden tube"
25m42s: The designer who drew D-linerollers made them too narrow. Called him. Now fixed.
48m30s: Don't trust spools to be 5 cm radius. Measure them and input into firmware the real radius.
51m5s: Noted down radius onto spool.
51m50s: Pro tip about spool/gear mounting.
54m35s: Starting to place out spools.
57m10s: Important note regarding D-lineroller placement. Rotate them appropriately.
58m50s: Close-up of wood screw.
1h23s: Pro tip: Furniture pods on back of ceiling plate.
1h9m45s: Close-up of mounted D-lineroller.
1h17m1s: You can tie lines from heat break to corner clamps to support/stiffen up hot end.
1h18m1s: Pushing 608 bearings into place.
1h18m42s: Pro tip: route thermistor wire inside heat cartridge wire's heat resistant sleeve.
1h19m50s: Let's attach some line. 3x5 m on the D-spool.
1h25m22s: Using one D-line as a reference for the others.
1h26m20s: The Hangprinter Hitch.
1h33m55s: Close-up of D-lines tied into D-spool.
1h35m45s: Tom explains braided/fused line.
1h37m35s: Keep the three D-lines separate while reeling onto spool.
1h39m21s: Pro tip: Mark your spools with "A", "B", "C", and "D".
1h45m38s: Counter sinking hole for M8 bolt the quick and dirty way.
1h47m30s: Inserting 608 bearings again.
1h49m15s: Pro tip: Sandwich spacer tightly between 608 bearings.
1h53m15s: Starting on the ribbon cable.
1h54m40s: Pro tip: Thread a loop in from the top of D-linerollers first to catch the single line from below.
1h58m13s: D-linerollers, D-spool, and D-lines limit where we can place everything else on the ceiling plate.
2h16s: Trying to plan layout of ceiling unit. Stepper cables are short.
2h3m51s: More on the ribbon cable.
2h7m21s: Giving the ceiling plate directions their names.
2h8m3s: Naming convention: B/C are the symmetric/mirrored sides of the mover. A is the third side.
2h8m43s: What to keep in mind for ceiling plate layout.
2h17m3s: Soldering ribbon cable's mover end.
2h37m25s: Assembling ABC spools of ceiling unit.
2h42m7s: Secure spool with nyloc nut or by tightening two M8 nuts against each other.
2h45m25s: Pro tip: Align with bolt while inserting bearing-spacer-bearing in gear sandwiches.
2h54m11s: Making lines for the A, B, and C spools.
2h56m10s: Mounting the ribbon cable on the extruder holder.
Part 2
3h28m12s: "Tell the printer to feed out line"
3h44m: "Start leveling the mover"
3h52m1s: "We have six of these Beam Sliders. One on each side gets used for D-line."
3h54m43s: "Let's bring the print bed in place"
3h56m20s: "Home position will be vertically below our ceiling unit"
3h57m24s: Torbjørn uses spirit level on mover
4h2m30s: Using mover as aiming plumb
4h4m27s: Drawing marks below mover pivot points
Now going into an hour of measuring this
Explanation on RepRap forums
4h10m7s: First mover levitation.
4h12m10s: Measure ANCHOR_A_Y and parallelize A anchor.
4h13m27s: "As long as the lines between mover's pivot points and anchor's pivot points are parallel, then we're good."
4h14m1s: "Let's use the number 230" (cm from anchor to mover). Measuring/deciding ANCHOR_A_Y to be 2300.0 mm.
4h17m47s: Marking out line that is parallel with y-axis.
4h20m53s: To mark out y-parallel lines, start with going through lineroller.
4h25m32s: Placing out C anchor.
4h30m1s: Placing out B anchor.
4h37m25s: Measuring ANCHOR_C_X.
4h39m28s: "This thing is cut square." Getting the 90 degree angle between ANCHOR_C_X and ANCHOR_C_Y.
4h40m25s: Measuring ANCHOR_C_Y.
4h41m45s: "C anchor will have a negative x-position." ANCHOR_C_X is a negative number.
4h42m20s: Measuring ANCHOR_B_X.
4h43m41s: Measuring ANCHOR_B_Y.
4h44m23s: "Let's do some sanity checking." Sanity checker's formula: Sanity checkers formula.png
4h47m53s: "We are going to make two more measurements." ANCHOR_ABC_Z and ANCHOR_D_Z explanation.
