Libro
Release status: Concept
Description | A delta style reprap printer designed to be built at a public library.
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Libro is a RepRap 3D printer designed to be created at public library makerspaces. Design emphasis is placed on 'foolproof' ease of assembly, minimal tool use, and short overall component print time. This development was originally begun as a makerspace program for the Pueblo City-County Library District by David Hartkop, PCCLD Technology Trainer.
The RepRap Libro is constructed partly from 3D printed parts and partly from low-cost commonly available hardware. The table below lists the objects to be 3D printed. All of these objects are available for download through Makerbot Thingiverse here: http://www.thingiverse.com/thing:1063222
A second set of the same object files is available on github, along with the modified Marlin firmware for the RepRap Libro: https://github.com/qbit/RepRapLibro
Part Name | File Name (download from thingiverse or tinkercad) | Print Time (min) | Filament (g) | # to Print | Total Print Time (min) | Total Filament (g) |
Linear Bearings | 150901_repraplibro_linearbearings1_4up | 120 | 35 | 3 | 360 | 105 |
Carriage | 150908_repraplibro_carriage | 80 | 30 | 3 | 240 | 90 |
Extruder Hub | 150908_repraplibro_extruderhub | 85 | 30 | 1 | 85 | 30 |
Idler End | 150908_repraplibro_idlerend | 40 | 14 | 3 | 120 | 42 |
Motor End | 150908_repraplibro_motorend_2up | 81 | 27 | 3 | 243 | 81 |
Pulley Set | 150908_repraplibro_pulleysset | 6 | 3 | 3 | 18 | 9 |
Magnet Mount | 150914_repraplibro_magnetmount8_4up | 44 | 14 | 3 | 132 | 42 |
Small Spool Holder | 150922_repraplibro_smspoolholder01 | 35 | 13 | 1 | 35 | 13 |
Standard Spool Holder | 150922_repraplibro_spoolholder03 | 31 | 11 | 1 | 31 | 11 |
Magnet Angle Mounts | 150926_repraplibro_magangmts_2up | 20 | 7 | 3 | 60 | 21 |
Bowden Extruder | 151013_repraplibro_bowdenextruder | 128 | 43 | 1 | 128 | 43 |
Extruder Gears | 151009_repraplibro_extrudergears | 41 | 15 | 1 | 41 | 15 |
Print Settings: | Three shells, 0.3 mm/layer, 15% infill, using raft & supports | Grand total print time: | 25 hours | |||
Grand total filament: | 502 g |
Part No. | Part | Description (enter as web search term!) | Category | For What steps: | Step # | Quantity |
1 | Super glue | standard fast drying cyanoacrylate super glue | Adhesives | Connector rod | Step 2.4 | 1 |
2 | 2-part epoxy glue | tubes of J-B Weld type heavy duty hard-setting 2 part epoxy | Adhesives | Connector rod | Step 2.4 | 1 |
3 | hot melt glue | sticks of hot melt glue for use with a glue gun to glue misc. parts | Adhesives | Wiring the machine | Step 2.6 | 1 |
4 | Stepper Motor | Nema 17 Stepper Motor Bipolar 2A 84oz.in 48mm length, 4-lead | Electronics | Linear motion legs & extruder unit | Steps 2.2, 2.3 | 4 |
5 | microcontroller | Arduino Mega 2560 board | Electronics | Wiring the machine | Step 2.6 | 1 |
6 | driver carrier board | RAMPS shield for Arduino | Electronics | Wiring the machine | Step 2.6 | 1 |
7 | stepper driver module | A4988 Stepper Driver Module | Electronics | Wiring the machine | Step 2.6 | 4 |
8 | lever microswitch | DPST miniature microswitch with lever | Electronics | Wiring the machine | Step 2.6 | 3 |
9 | Thin hook-up wire | 20 foot spool of 26 gage hook up wire, Yellow | Electronics | Wiring the machine | Step 2.6 | 1 |
10 | Thicker hook-up wire | 6 feet of red & black wire pair, 20 gage | Electronics | Assembling & wiring the machine | Steps 2.5, 2.6 | 1 |
11 | DC Power supply | 12volt DC filtered power supply rated 6 amps | Electronics | Wiring the machine | Step 2.6 | 1 |
12 | USB printer wire | 8 foot long USB printer-connection type USB cable | Electronics | Assemble the machine | Step 2.5 | 1 |
13 | crimp connectors | Dupont Jumper Wire Cable Female Pin Crimp Connector 2.54mm | Electronics | Wiring the machine | Step 2.6 | 50 |
14 | crimp sockets, 4 wire | 2.54mm 1x4P Dupont Connector Housing, Female | Electronics | Wiring the machine | Step 2.6 | 5 |
15 | crimp sockets, 2 wire | 2.54mm 1x2P Dupont Connector Housing, Female | Electronics | Wiring the machine | Step 2.6 | 5 |
16 | electrical box | Raco 11.5-cu in 1-Gang Metal New Work Wall Electrical Box | Hardware | Linaer motion leg | Step 2.3 | 6 |
17 | electrical conduit | 1/2” EMT, 10 ft section | Hardware | Linaer motion leg | Step 2.3 | 2 |
18 | conduit fitting | 1/2” EMT connector, compression type | Hardware | Linaer motion leg | Step 2.3 | 12 |
19 | tension spring | 3/8” x 1-15/32” x .035” extension spring | Hardware | Linaer motion leg | Step 2.3 | 3 |
20 | rubber feet | misc self-adhesive rubber feet for bottom of machine | Hardware | Assembling the machine | Step 2.5 | 6 |
21 | glass build plate | 8” x 10” rectangular glass, 12” diameter circular mirror | Hardware | Assembling the machine | Step 2.5 | 1 |
22 | ball bearing | metric press fit bearing O.D 17mm x I.D. 6mm x 6mm thick | Hardware | Extruder unit | Step 2.2 | 1 |
23 | steel balls | 1/2 inch steel ball bearings | Hardware | Connector Rod | Step 2.3 | 12 |
24 | hot end for 3D printer | Assembled All Metal J-head Hotend with Cooling Fan for Bowden Extruder Reprap and tube for distance | Hardware, specialty | Center hub | 2.1 | 1 |
25 | brass extruder gear | 3D printer Bowden extrusion gear, I.D. 5mm, O.D. 10mm | Hardware, specialty | Extruder unit | Step 2.2 | 1 |
26 | push-in fitting | nylon tube male connector push-in fitting for tube O.D. 4mm | Hardware, specialty | Extruder unit | Step 2.2 | 2 |
27 | miniature ball bearings | metric press fit bearing O.D 10mm x I.D 5mm x 4mm thick | Hardware, specialty | Extruder unit | Step 2.2 | 2 |
28 | spring - extruder tension | miniature round wire compression springs, O.D. 6mm, Length 20mm | Hardware, specialty | Extruder unit | Step 2.2 | 4 |
29 | ball chain | stainless ball chain laniards for dog tags (30 inches long each) | Misc | Linaer motion leg | Step 2.3 | 6 |
30 | wooden base/top | 18” diameter pine wooden circle, 1-1/4” thick | Misc | Assembling the machine | Step 2.5 | 2 |
31 | magnet | 1/2” diameter x 1/4” thick rare earth magnet, countersink hole | Misc | Center hub & linear motion legs | Steps 2.1, 2.3 | 12 |
32 | tube for extruder | FEP plastic tube, O.D. 4mm, length 95cm | Misc | Extruder unit | Step 2.2 | 1 |
33 | machine grease | tube of synthetic machine grease for metal tubing & bearings | Misc | Assemble the machine | Step 2.5 | 1 |
34 | sandpaper | sheets of 200 grit sand paper for sanding metal tubing | Misc | Linear motion leg | Step 2.3 | 4 |
35 | Zip ties | 6” zip ties | Misc | Wiring the machine | Step 2.6 | 20 |
36 | screw - motor mount | M3 x 8mm long metric machine screw | Nuts & bolts | Linear motion legs & extruder unit | Steps 2.2, 2.3 | 16 |
37 | screw - clamps & misc | #4 x 3/8 inch long pan head sheet metal screw | Nuts & bolts | Linear motion legs & machine assembly | Steps 2.3, 2.5 | 50 |
38 | screw - magnet mount | #8-32 x 1/2 inch long machine screw | Nuts & bolts | Center hub & extruder unit & linear motion legs | Steps 2.1, 2.3 | 20 |
39 | screw - box mounting | 2-1/2 inch deck screw | Nuts & bolts | Assembling the machine | Step 2.5 | 12 |
40 | screw - hotend mount | #6-32 x 3/4 inch long machine screw | Nuts & bolts | Center hub | Step 2.1 | 2 |
41 | nut - hotend mount | #6-32 zinc nuts | Nuts & bolts | Cente hub | Step 2.1 | 2 |
42 | nail - idler pulley | 3/4” roofing nail, zinc coated, 1/8” diameter | Nuts & bolts | Linear motion leg | Step 2.3 | 3 |
43 | bolt - extruder shaft | M5-0.80 x 45mm long hex cap bolt | Nuts & bolts | Extruder unit | Step 2.2 | 1 |
44 | nut - extruder shaft | M5-0.80 nylon lock nut | Nuts & bolts | Extruder unit | Step 2.2 | 1 |
45 | washer - extruder shaft | M5 flat zinc washer | Nuts & bolts | Extruder unit | Step 2.2 | 4 |
46 | setscrew - extruder | M6 x 12mm long setscrew | Nuts & bolts | Extruder unit | Step 2.2 | 1 |
47 | screw - extrude tension | M3-0.5 x 40mm metric machine screw | Nuts & bolts | Extruder unit | Step 2.2 | 2 |
48 | screw - extruder hinge | M3-0.5 x 30mm metric machine screw | Nuts & bolts | Extruder unit | Step 2.2 | 1 |
49 | wingnuts - extruder tension | M3 metric wing nuts | Nuts & bolts | Extruder unit | Step 2.2 | 2 |
50 | washer - extruder tension | M3 miniature flat zinc washers | Nuts & bolts | Extruder unit | Step 2.2 | 4 |
51 | threaded rod | 12 inch section of 1/4-20 allthread, steel zinc plated | Nuts & bolts | Connector rod | Step 2.4 | 6 |
52 | nuts - connector rod | 1/4-20 zinc nuts | Nuts & bolts | Connector rod | Step 2.3 | 12 |
