Libro
Release status: Concept
Description | A delta style reprap printer designed to be built at a public library.
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Libro is a RepRap 3D printer designed to be created at public library makerspaces. Design emphasis is placed on 'foolproof' ease of assembly, minimal tool use, and short overall component print time. This development was originally begun as a makerspace program for the Pueblo City-County Library District by David Hartkop, PCCLD Technology Trainer.
PART NAME | FILE NAME | PRINT TIME (min) | FILAMENT (g) | # TO PRINT |
Linear Bearings | 150901_repraplibro_linearbearings1_4up | 120 | 35 | 3 |
Carriage | 150908_repraplibro_carriage | 80 | 30 | 3 |
Extruder Hub | 150908_repraplibro_extruderhub | 85 | 30 | 1 |
Idler End | 150908_repraplibro_idlerend | 40 | 14 | 3 |
Motor End | 150908_repraplibro_motorend_2up | 81 | 27 | 3 |
Pulley Set | 150908_repraplibro_pulleysset | 6 | 3 | 3 |
Magnet Mount | 150914_repraplibro_magnetmount8_4up | 44 | 14 | 3 |
Small Spool Holder | 150922_repraplibro_smspoolholder01 | 35 | 13 | 1 |
Standard Spool Holder | 150922_repraplibro_spoolholder03 | 31 | 11 | 1 |
Magnet Angle Mounts | 150926_repraplibro_magangmts_2up | 20 | 7 | 3 |
Bowden Extruder | 151013_repraplibro_bowdenextruder | 128 | 43 | 1 |
Extruder Gears | 151009_repraplibro_extrudergears | 41 | 15 | 1 |
Download the build files for the RepRap Libro here: http://www.thingiverse.com/thing:1063222
You can download the configured Marlin firmware for your RepRap Libro Here on Github:
https://github.com/qbit/RepRapLibro
Part No. |
Part |
Description (enter as web search term!) |
Category |
For What steps: |
Step # |
Quantity |
1 |
Super glue |
standard fast drying cyanoacrylate super glue |
Adhesives |
Connector rod |
Step 2.4 |
1 |
2 |
2-part epoxy glue |
tubes of J-B Weld type heavy duty hard-setting 2 part epoxy |
Adhesives |
Connector rod |
Step 2.4 |
1 |
3 |
hot melt glue |
sticks of hot melt glue for use with a glue gun to glue misc. parts |
Adhesives |
Wiring the machine |
Step 2.6 |
1 |
4 |
Stepper Motor |
Nema 17 Stepper Motor Bipolar 2A 84oz.in 48mm length, 4-lead</FONT></SPAN></FONT></P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Electronics</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Linear motion legs & extruder unit</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Steps 2.2, 2.3</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 4</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 5</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> microcontroller</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Arduino Mega 2560 board</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Wiring the machine</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Step 2.6</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 1</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 6</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> driver carrier board</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> RAMPS shield for Arduino</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 7</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> stepper driver module</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> A4988 Stepper Driver Module</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 8</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> lever microswitch</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> DPST miniature microswitch with lever</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 3</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 9</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Thin hook-up wire</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 20 foot spool of 26 gage hook up wire, Yellow</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 10</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Thicker hook-up wire</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 6 feet of red & black wire pair, 20 gage</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Assembling & wiring the machine</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Steps 2.5, 2.6</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 11</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> DC Power supply</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 12volt DC filtered power supply rated 6 amps</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 12</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> USB printer wire</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 8 foot long USB printer-connection type USB cable</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Assemble the machine</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Step 2.5</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 13</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> crimp connectors</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Dupont Jumper Wire Cable Female Pin Crimp Connector 2.54mm</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 50</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 14</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> crimp sockets, 4 wire</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 2.54mm 1x4P Dupont Connector Housing, Female</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 5</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 15</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> crimp sockets, 2 wire</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 2.54mm 1x2P Dupont Connector Housing, Female</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 16</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> electrical box</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Raco 11.5-cu in 1-Gang Metal New Work Wall Electrical Box</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Hardware</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Linaer motion leg</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> Step 2.3</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 6</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 17</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> electrical conduit</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 1/2â EMT, 10 ft section</P> </TD> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 2</P> </TD> </TR> |
<P ALIGN=CENTER STYLE="font-style: normal; font-weight: normal; text-decoration: none"> 18</P> </TD> |
<P ALIGN=RIGHT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> conduit fitting</P> </TD> |
<P ALIGN=LEFT STYLE="font-style: normal; font-weight: normal; text-decoration: none"> <FON |
