Kuba3D
Revision as of 02:23, 9 September 2016 by Boylucky (talk | contribs)
Page currently under construction
Kuba3D
Release status: experimental
XYZ printer
none
[http://]
Introduction
Kuba3D is a small dimension cartesian 3D printer designed for desktop use and intended for hobbyist without previous experience with 3D printing. The print volume is currently only 100x85x85 (will be extended in next upgrade to 100x100x100) with cold glass bed. Hot end is J-head Bowden Hotend for 1.75mm PLA or ABS filament. Using NEMA17 stepper motors, Arduino Mega 2560 with Ramps 1.4 and A4988 StepStick stepper drivers. Construction is made of alu profiles connected by printed parts. X and Y axes use linear guideways, Z axe uses 8mm smooth rods. The printer is currently still in development stage.
Dimensions
The external dimensions of the printer is 230x230x300mm and print volume only 100x85x85mm (will be extended in the next upgrade to 100x100x100mm).
