I3 X axis assembly
Revision as of 06:15, 14 August 2015 by Qing (talk | contribs)
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Need Parts
  • 1. 2×M8*370 mm Axis
  • 2,3,4,5. 4×RP plastic parts
  • 6. 8×8UU Bearing
  • 7. 2×M5 NUT
  • 8. 1×Pulley
  • 9. 2×Single Bearing
  • 10.8×M3flat gasket
  • 11.4×M3 LOCK NUT
  • 12.3×M3*12 screw
  • 13.2×M3*20 Countersunk head
  • 14.1×M3*25 screw
  • 15.2×M3 NUT 2×M3*6 blunt end headless screws
  • 16.1×Synchronous belt
  • 17.8×Tie
  • 18.1×NEMA 17
RP Plastic Part
Step 1
You need the 5mm dill, Set counterclockwise rotation and drill progressively and carefully along the axis.
5mm drill
5mm drill
Step 2
You need 3mm drill.Set counterclockwise rotation and drill progressively and carefully along the axis.
3mm drill
3mm drill
Step 3
You need 8mm drill.Set counterclockwise rotation and drill progressively and carefully along the axis.
8mm drill
8mm drill
X End Idler & X End Motor assembly
Step 1
You need the 15 parts.First put the M3 nut in the hole, then tighten the M3*6 blunt end headless screws.
M3 NUT
Step 2
You need the 9,10,11,14 parts.Please assemble in accordance with the picture.
M3*25 screw× 1,M3 LOCK NUT ×4 ,M3 flat gasket ×2 ,Single Bearing ×2
Step 3
You need the 7 parts.Please install the M5 nut to plastic parts (red mark).
M5 Nut ×2
Step 4
Push two LM8UU linear bearings in the X End Idler and two LM8UU linear bearings in the X End Motor. They can be pushed with hands but you can use a rubber mallet carefully if necessary.
8UU×4
X Carriage
Insert four LM8UU linear bearings on the X Carriage and fix them with eight zip-ties. Make sure to put the « head » of the zip-tie on bearings side.
8UU×4
X-Axis assembly
Step 1
Slide the X Carriage assembly carefully through smooth rods.
Step 2
Push two smooth rods M8x370 mm through the X End Motor. Use a rubber mallet carefully if necessary.
Step 3
Insert the X End Idler assembly and adjust the distance between both Z-axis。
X-axis motor assembly
You need the 8,12,18 parts.Please assemble the X axis motor according to the picture.
NEMA17 motor × 1,Pulley ×1,M3*12 screw×3
