I3 X axis assembly
Revision as of 02:55, 12 August 2015 by Qing (talk | contribs) (Created page with "{{Languages}} ==Need Parts== 800px * 1. 2×M8*370 mm Axis * 2,3,4,5. 4×RP plastic parts * 6. 8×8UU Bearing * 7. 2×M5 NUT * 8. 1×Pulley * 9...")
Need Parts
  • 1. 2×M8*370 mm Axis
  • 2,3,4,5. 4×RP plastic parts
  • 6. 8×8UU Bearing
  • 7. 2×M5 NUT
  • 8. 1×Pulley
  • 9. 2×Single Bearing
  • 10.8×M3flat gasket
  • 11.4×M3 LOCK NUT
  • 12.3×M3*12 screw
  • 13.2×M3*20 Countersunk head
  • 14.1×M3*25 screw
  • 15.2×M3 NUT 2×M3*6 SCREWS
  • 16.1×Belt
  • 17.8×Tie
  • 18.1×NEMA 17
RP Plastic Part
Step 1
You need the 5mm dill, Set counterclockwise rotation and drill progressively and carefully along the axis.
5mm drill
5mm drill
Step 2
You need 3mm drill.Set counterclockwise rotation and drill progressively and carefully along the axis.
3mm drill
3mm drill
Step 3
8mm drill
8mm drill
Assembly accessories
Step 1
