I3 The main panel frame assembly
Revision as of 06:15, 14 August 2015 by Qing (talk | contribs)
Bill of materials | The main panel frame assembly | Y-axis assembly | X-axis assembly | Z-axis assembly
Connecting X-axiz and Z-axiz | Power and LCD assembly | Extruder assembly | Heating bed assembly
power switch and end stops assembly | Control Board assembly and wiring | Circuit Diagram
Acrylic Frame Diagram
  • 1,front sheet
  • 2,left side sheet
  • 3,right side sheet
  • 4,5,6,7,8,9 Z-axis motor mounting plate
  • 10,11 Z axis rod,thread fixed sheet
  • 12,13,14 Y axis,back side thread fixed sheet
  • 15,16 Y axis motor sea
  • 17,18,19 Y axis,front side thread fixed sheet
  • 20,21,22 Y axis synchronous belt wheel
  • 23,installed below of the heat bed
  • 24,25 Z axis the top of Z rod fixed sheet
  • 26,Y axis axis synchronous belt,be installed movable heat bed
Need parts:
  • 1,front sheet
  • 2,left side sheet
  • 16×M3 NUT
  • 16×M3*16 screw
  • 16×M3 flat gasket
Step 1
Take the left plate 2 ,and then put into the M3 nut(red mark),Inserted into the left side of the main panel 1 (top panel LCD main circular hole to the right) and then use screw M3 * 16 with tight(red mark).
Step 2
Take the right side sheet3,the same as the above.
Step 3
After do it ,as like this picture.
Step 4
Please put the M3 nut into the left side of the motor fixing plate 4,5,6(red mark),Then fixed with the M3 * 16 screws(red mark).
Step 5
Put the M3 nut inserted into the lower left of the main frame and use M3 * 16 screws to tight.
Step 6
Right side motor mounting platethe same as the above.
