I3 The main panel frame assembly
Acrylic Frame Diagram
- 1,front sheet
- 2,left side sheet
- 3,right side sheet
- 4,5,6,7,8,9 Z-axis motor mounting plate
- 10,11 Z axis rod,thread fixed sheet
- 12,13,14 Y axis,back side thread fixed sheet
- 15,16 Y axis motor sea
- 17,18,19 Y axis,front side thread fixed sheet
- 20,21,22 Y axis synchronous belt wheel
- 23,installed below of the heat bed
- 24,25 Z axis the top of Z rod fixed sheet
- 26,Y axis axis synchronous belt,be installed movable heat bed
Need parts:
- 1,front sheet
- 2,left side sheet
- 16×M3 NUT
- 16×M3*16 screw
- 16×M3 flat gasket
Step 1
Take the left plate 2 ,and then put into the M3 nut(red mark),Inserted into the left side of the main panel 1 (top panel LCD main circular hole to the right) and then use screw M3 * 16 with tight(red mark).
Step 2
Take the right side sheet3,the same as the above.
Step 3
After do it ,as like this picture.
Z-axis assembly
Step 1
Please put the M3 nut into the left side of the motor fixing plate 4,5,6(red mark),Then fixed with the M3 * 16 screws(red mark).
