HuxleyYAxis
General
This page and its peers should guide you through assembling a RepRap Huxley from the TechZone kit, or from parts you have printed which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (24 Dec 2010)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Huxley assembly from the Main Huxley page or from the TechZone Huxley Page
Whene assembling the Y Axis, it is OK to actually tighten the bolts/nuts since it is all aligned by the frog plate and later installation into the frame.
Y 180
On the left is a picture of the parts used to make the Y Axis 180 side. See the image below on assembling the Y Axis to view the assembled Y 180 parts.
Y 360
Connecting to Frog Plate
Install the Build Platform
I would not install the Build platform at this time.Once you are ready to install the build platform, you'll want to insert the 2 smooth rods you'll use into the back holders, then slide them into the bearings on the Y axis. Once pushed all the way through those, place them into the front rod holders. Once everything is in place, tighten it down and make any alignment adjustments you need to.
