Hangprinter
Revision as of 18:24, 15 December 2014 by Tobben (talk | contribs)
Hangprinter
Release status: Idea stage/Experimental
A RepRap using walls and ceiling as its frame
OpenSCAD
Ideas the design is meant to implement
  • A print-head that hangs down in a string from the ceiling.
  • Put all the hardware (except AC/DC-converter) in one single unit.
It should be possible to install in a house by simply by attaching strings to anchor points in walls and ceiling, power wire to circuit board and filament to extruder.
Assumed difficulties
  • Special z-compensating firmware will need to be written in order to acheive plane enough xy-planes if print radius is > ca 2 cm.
  • It will probably need to be a slow printer, since it relies on tight strings for stability.
  • Feeding filament and carrying power wires around while avoiding xy-rotations will require special solutions.
  • A custom designed extruder, because all motor shafts will have to be paralell with the z-direction in order to avoid xy-torque induced by them.
  • Finding a reasonable home position without imposing lots of constraints on the print start process and/or the position of anchor points.
  • Convincing people to put anchor points (screws) in walls and ceiling might prove difficult.
Assumed advantages From Using House as Frame
  • Low part count.
  • Easy and fast to build.
  • Very easy to install and distribute.
  • Huge build volume (especially height).
  • When printer is not running, noe could retract all the strings. Hanging it in the z-achor point (the ceiling) with no dangeling strings might be elegant storage solution. Could make it popular in big cities, where indoor area is scarce.
