HackerBot structure
HackerBot Documentation
Base structure
- Hackerbot 2.0 uses MISUMI profile, but you can also use Bosch-Rexroth
- 600mm profile should be M8 threaded one side (length of thread about 40mm)
- Assemble the frame structure checking the squareness and assemble it also on a flat workbench
- Insert first all the pre assembly nuts into the slots, then assemble all the pre assembly brackets
- Last step is the n.4 Brackets post assembly (red brackets, check the photo)
- TODO: two brackets for internal PMMA cover
qty | part name | description/notes |
11 | EFSFB6-3030-450 | 3-slots 30mm aluminum extrusion 450mm |
4 | EFSTB6-3030-600 | 2-slots 30mm aluminum extrusion 600mm |
2 | EFSB6-3030-450 | 4-slots 30mm aluminum extrusion 450mm |
40 | HBLFSB6-C-SET | Bracket set (pre assembly) |
2 | HBLFSB6-C-SET | Bracket set (pre assembly) |
2 | HBLBS6 | Internal bracket 8mm slot |
4 | FBF33-8-30 | M8 rubber foot |
4 | HFCB6-3030-B | Set plugs profile |
** STRUCTURE COMPLETE **
** GO TO: HackerBot XY system **
