HackerBot pre-flight check
HackerBot Documentation
** SECTION INCOMPLETE OR OUTDATED **
Finalize assembly
- Axis support plate should be orthogonal to the base. Use a caliper to check that distance between plates, shafts, etc. are equal
- tighten the (four) support plates screws
- move the Head to a corner and tighten the relative screws (only the screws thats belong to the support plate), then move to the other corners and do the same.
- tighten the cubic slider grub screw and check if the Head move smoothly. Head should be moving with little force applied to both sliders.
- pull the cubic sliders belt and tighten the belt clamps
- Check Z axis. It should move up and down very smoothly. Center it and tighten the screws.
- double check hotend grub screw. DONT tighten too much
- fasten and mark every other screw
- use a drop of oil on shafts
- grease on trapezoidal screw
Electrical
- ELECTRICAL CHECK SHOULD BE DONE WITHOUT POWER CABLE CONNECTED!
- check that glue has been applied to the mains power (check build manual)
- gently pull every cable and check that are really well fixed
- Check fuse
- Connect controller with USB cable and do a check.
- Test power supply only. BE VERY CAREFUL, you should do electrical wirings and check ONLY if you are a tech.
- Power the controller & motors. Check LCD temps, heat hotends, heat heatbed, move motors.
- Check motor direction
- Check endstops (M119) and trying HOMING (G28). Usually first movements are jerky.
- Check Z axis doing a G1 Z[max] (ex: G1 Z250)
Printer TEST
- Move manually head on the PrintBed and fine tune the Z: nozzles should touch the printbed
- Check that the Z zero is OK in all the four corner of the printbed
- Home and double check that hotends hover the PrintBed
- Check Heaters and HeadBed temperature
- (preheat) turn on Heatbed: M140 S60
- (preheat) turn on extruder: M104 S100
- clean extruder from thermal paste and, if any, check temp with an external thermometer
- test FAN1: M106 S255 (off: M106 S0)
- test FAN2: M42 P8 S200 (off: M42 P8 S0)
- turn on extruder: M104 S260 . AND test extrusion directly pushing ABS into the hotend.
- NO burnt smell? we're almost done!
- check extruder motor correct direction. Try to extrude some filament: G1 E10 F1000 ; G92 E0
- TEST HOMING
- Test the printer moving axis from the LCD panel.
- Use the File:Vertex-max speed Hackerbot printer test.STL with no extruder active
- Test the printer at 100% feed rate (so 50mm/s print, 200mm/s travel)
- Test the printer at 200% feed rate (so 100mm/s print, 400mm/s travel)
- Repeat test with File:Vertex-max speed Hackerbot printer test.STL with extruder active
- Extruder should not lose filament
Test print area and basic motion
Slice and print: File:Square-hex-circle Hackerbot printer test.STL
This is a pretty good test to check the printer.
Test rapid moves / max speed
Slice and print: File:Vertex-max speed Hackerbot printer test.STL
The printer should move correctly with rapids not loosing steps.
Test print quality
ABS:
PLA:
** PRINTER READY TO GO **
