HackerBot door
Revision as of 08:32, 22 October 2015 by Balestrino (talk | contribs)
HackerBot Documentation
** SECTION INCOMPLETE OR OUTDATED **
Door assembly
qty | part name | description/notes |
1 | Door PMMA panel | |
2 | Aluminum extrusion profile 20x20 length 405mm | |
2 | Aluminum extrusion profile 20x20 length 382mm | |
4 | Cubic joint 20x20 2 way | Bosch 3842524484 |
2 | Hinge | Bosch 3842544526 |
1 | Handle | what you like! just use a small cube |
Create a square with four 20x20 profiles. Insert the cubic joints
'Remember the M4 hole & fasten the handle in the middle of 382mm extrusion
Insert PMMA panel before tighten screws:
Use hinges to place door on the front of the printer
** DOOR COMPLETE **
** GO TO >> HackerBot print area **
