HackerBot Build Manual
Revision as of 18:45, 26 January 2014 by Balestrino (talk | contribs) (Step 32: Assembling Print area)
HackerBot Documentation
Before You Begin
If you are here probably you are going to build an Hackerbot by yourself.
Tools needed to build ground up the Hackerbot:
  • Drills
  • Bandsaw
  • Lathe
  • Grinder
  • Caliper (small one and big one 500mm)
  • Drills, taps, reamers
  • Solder gun
  • Multimeter
  • Crimp tools
and a some goods:
(NOT UPDATED RIGHT NOW) Complete bill of materials for HackerBot v 1.3: HackerBot BOM
Downloads
HackerBot project design files are on GitHub:
If you have question, doubts, applause just drop a mail at info @ oshw.it
Assembly Instructions
Before assembling a HackerBot, make sure you have all the parts necessary.
Every assembly / build step is documented with a photo and a short but clear description.
Follow all the steps and ask if in doubt.
And please take care of all the safety precautions when assembling, machining, whatever.
Remember: nothing is more important than safety
Aluminum Frame
Base structure
Structure
qty part name description/notes
4 Aluminum profile 30x30 450mm
8 Internal bracket (Bosch 3842535577)
11 Plexy support
Step 1: base with supports
Take the four 30x30 structure profile of length 450mm. Insert the plexiglass support (3d printed) in the profile grooves in the following manner:
  • three supports on three profiles
  • two supports on the last one profile
HackerBot step 1
Step 2: base with internal brackets
Create a square with profiles and add the internal brackets, one each end of profile
HackerBot step 2
Check out the correct placement of Internal Bracket:
HackerBot step 2 detail
Columns
Columns
4 Aluminum profile 30x30 600mm
8 Plexy support 3mm
Step 3: tap M8 vertical strut
Tap M8 one side of 600mm vertical profile. Taps are for printer rubber feet
HackerBot step 3
Step 4: tighten base with column
Link the base with the vertical profiles. Check that dimension are equal with a caliper and tighten the screws.
HackerBot step 4
Step 5: insert supports in the column
Insert two plexiglass support in one column. The supports are only on internal face
Repeat for every column.
check the photo:
HackerBot step 5
check out: total 8 plexyglass supports.
Mid plane profiles
Mid plane
23 Plexy support 3mm
8 Internal bracket Bosch 3842535577
1 Z stepper plate File:Z-stepper plate.PDF
2 M6 T-head bolt Bosch 3842523921
2 T-nut Bosch 3842523925
Step 6: lower Z profile / Z motor mount
Put two plexiglass supports on the upper side and two and lower side:
HackerBot step 6.1
Mount the Z stepper plate in the mid of the profile:
HackerBot step 6.2
Using two M6 T-head bolt and two T-Nut.
TIP: measure 185mm from the edge of the profile.
Place two internal bracket at the end of the profile:
HackerBot step 6.3
Place the profile in the struct with a distance of 46 mm from the base profile:
HackerBot step 6.4
Step 7: front middle profile
Take the mid profile for the front side and insert in one groove three plexy supports and two internal brackets:
HackerBot step 7.1
Fix it and leave a gap of 85 mm between this profile and the lower one:
HackerBot step 7.2
Step 8: right middle profile
Take the profile for the right middle side and insert two plexy supports and two internal brackets:
HackerBot step 8.1
HackerBot step 8.2
Step 9: left middle profile
Take the profile for the left middle side and insert two plexy supports and two internal brackets:
HackerBot step 9.1
HackerBot step 9.2
Upper Z profile
Upper Z backside profile
1 Aluminum profile 30x30 450mm
2 Internal bracket Bosch 3842535577
3 Plexy support 3mm
Step 10: Upper Z backside profile
Place one plexiglass support in each backside columun:
HackerBot step 10.1
In the Upper Z profile put three supports upside and two downside.
Put the internal brackets at the end of the profile:
HackerBot step 10.2
Fix it with a distance equal to 342 mm between the internal vertical surfaces of z-upper profile and mid profile on the rear side:
HackerBot step 10.3
Top square structure
Top
20 M6 T-head bolt Bosch 3842523921
20 T-nut Bosch 3842523925
9 Plexy support 3mm
Step 11: Top Backside profile
Take two supports and insert a M3 square nut.
Insert one support to the left side (see photo) and other one to the right side:
HackerBot step 11.1
Put three plexy support in the aluminum profile and two internal brackets:
HackerBot step 11.2
Mount the profile in the backside:
HackerBot step 11.3
Step 12: Top Right profile
Per side insert two plexy support in the vertical strut. Total four supports
HackerBot step 12.1
Put two plexy support in the aluminum profile and two internal brackets:
HackerBot step 12.2
Mount the profile in position:
HackerBot step 12.3
Step 13: Top Left profile
Do the same as step 12 but for left side.
Step 14: Top Front profile
Put two internal brackets:
HackerBot step 14.1
HackerBot step 14.2
** STRUCTURE COMPLETE **
XY systems
Support plates
Top
1 Front right support plate File:Support plate 50x50 L.80mm Front-Right.PDF
1 Front left support plate File:Support plate 50x50 L.80mm Front-Left.PDF
1 Back right support plate File:Support plate 50x50 L.140mm Back-Right.PDF
1 Back left support plate File:Support plate 50x50 L.140mm Back-Left.PDF
Step 15: Back Right plate
Using four M6 T-head bolt fix in the corner the support plate:
HackerBot step 15
Step 16: Back Left plate
HackerBot step 16
Step 17: Front Left plate
Using two M6 T-head bolt fix in the corner the support plate:
HackerBot step 17
Step 18: Front Right plate
HackerBot step 18
XY system
Step 19: Cubic Slider
Cubic Slider
4 Cubic slider
8 Cubic slider belt clamp File:Belt clamp.stl print 100% infill
24 M3x12 screw kit
4 Cubic slider PTFE bushing
Assemble the cubing slider:
HackerBot step 19
and take care when inserting the PTFE bushing. If possible use a 8mm reamer after.
Step 20: XY Shafts
XY Shafts
2 Shaft 8mm. length 465mm
2 Shaft 8mm. length 438mm
8 GT2 20 teeth pulley (8mm bore)
8 Shim POM / Delrin
8 608 Bearings
8 Bearing housing 3D printed
32 M3x16 screw kit fixes the bearing supports with support plates
Using the cubic slider assemble the shafts as in photo:
HackerBot step 20
HackerBot step 20.1
double check:
  • the correct orientation of Cubic slider's
  • shafts should not be touching the Supports plate
  • Cubic slider's should be running well on the shafts, and shafts should turn easily
DON'T tighten the screws.
Step 21: XY Belts
XY Belts
4 GT2 open belt length 830mm XY core belts
Place the four belts like as show below:
HackerBot step 21
DON'T pull the belts.
Step 22: XY Motors
XY Motors
2 Stepper motor Nema 17 2.5A (or 1.7A), shaft 5mm
2 GT2 20 teeth pulley 5mm bore
2 GT2 20 teeth pulley 8mm bore
1 GT2 closed belt 77 teeth SDP-SI.COM (6R51M077060)
1 GT2 closed belt 66 teeth SDP-SI.COM (6R51M066060)
Y Motor (right side)
Use a GT2 closed belt 66 teeth:
HackerBot step 22
X Motor (backside)
Use a GT2 closed belt 77 teeth:
HackerBot step 22.1
Step 23: XY Motor belt tighteners
Belt Tightner
1 Belt Tightener with one 624zz bearing, File:Belt tightener.PDF
1 Belt Tightener short with one 624zz bearing File:Belt tightener small.PDF
1 624zz bearing
2 M3x15 screw with 2 M3 nuts
2 M3x20 screw with 2 M3 nuts
6 M3 washer
HackerBot step 23
HackerBot step 23.1
HackerBot step 23.2
Head
Step 24: Head assembly
Head
2 Shaft 8mm length 370mm Head shaft support
1 Head v2 File:Head v2 FAN.stl File:Head v2 fan support 60.stl
4 Linear Bearing LM8UU
2 Pneumatic fittings
4 M3x8 grub screw fixes the hotends
Insert the four linear bearings in the head, fasten the pneufit and the grub screws:
HackerBot step 24
Insert shafts in the head
HackerBot step 24.1
Place the head assembly AND take care to not force anything when mounting it:
HackerBot step 24.2
TIPS:
  • for easy mounting put the cubic sliders on a side
** XY COMPLETE **
Z system
Step 25: Print area support assembly
Print area support
2 LM10LUU 10mm linear bearing with housing
1 LM10LUU screw kit 8x M5x20 screw, 8x M5 washer
1 Print area support L-shaped File:Print area support-L-shaped plate.PDF
1 Z endstop holder
1 Trapezoidal nut with 4x M4x20 screw
Fasten LM10LUU linear bearings and the L-shaped plate with M5 screws (Linear bearings must be placed on the internal side of L-shape) and, on the other side, the trapezoidal nut through M4 screws like:
HackerBot step 25
Step 26: Z axes and trapezoidal thread
Print area support
1 Trapezoidal screw 12x3, length: 380mm 12mm length machined to 10mm diameter
2 Z shaft 10mm length 390mm 10mm
Screw the trapezoidal thread in the nut and to the L-shaped plate.
Insert the two shafts in the LM10LUU bearings
HackerBot step 26
Step 27: Z stepper motor assembly
Z motor
1 Z Stepper motor nema 17 1.7A
1 Z Stepper motor screw kit 4x M4x20 screws, 4x M4 washer
1 Motor-Trapezoidal screw coupler flexible coupling 5 mm and 8 mm diameter
Take the stepper motor for the z-axis and join the motor shaft toward top to stepper plate with the screws and washers (stepper motor kit of this section checklist).
On the other side of the stepper plate, add to the motor shaft (5mm of diameter) the flexible coupling.
HackerBot step 27
Step 28: Assembly of z-axes on structure
Z System
4 SK10 Shaft support 10mm shaft
10 Collar nut (Bosch 3842523925) used for stepper plate and SK10
10 T-Bolts (Bosch 3842523920) used for stepper plate and SK10
Widen the holes of shaft supports to 6mm of diameter, to allow the connection with the profiles trough M6 T-head bolt.
Join the shaft support to the mid-rear and upper z profiles with T-head bolts. Insert the z-axes in shaft support holes.
Now, join the free side of 8mm diameter of the coupling with the cylindrical part of the trapezoidal thread.
HackerBot step 28
Step 29:Print plate (Heatbed)
Print Plate (Heatbed)
1 Aluminium heatbed support File:Aluminium heatbed support.pdf
5 M5x20 - washer - nut
HackerBot step 29
Step 30: Z Endstop holder
Endstop holder
1 Z endstop tuning support
1 Z endstop knob use a grub screw to fix M4 threaded rod
1 Z endstop spring
1 Collar nut (Bosch 3842523925) used for Z endstop holder
1 T-Bolts (Bosch 3842523920) used for Z endstop holder
1 M4 threaded rod length 60mm
File:Hackerbot step 30.jpg
HackerBot step 30
** Z COMPLETE **
Door
Step 31: Door assembly
Door
1 Door PMMA panel
2 Aluminum extrusion profile 20x20 length 405mm
2 Aluminum extrusion profile 20x20 length 382mm
4 Cubic joint 20x20 2 way Bosch 3842524484
2 Hinge Bosch 3842544526
1 Handle what you like! just use a small cube
Create a square with the four 20x20 profiles, in the vertex insert the cubic joints
'Remember the M4 hole & fasten the handle on a 382mm extrusion
Insert PMMA panel before tighten screws:
HackerBot handle
Use hinges to place door on the front of the printer
HackerBot front door
** DOOR COMPLETE **
Print area
1 Print bed MK* heatbed or acrylic plate
1 Heatbed glass needed for MK* heatbeds
4 MK* Heatbed springs 25mm length compression spring (1.2mm wire)
4 M3x35 heatbed use a washer to avoid scratching the heatbed
First assemble and check: HackerBot MK Heatbed wiring
Insert the four M3 screws in the MK Heatbed holes with a washer between head screws and hot plate.
Fasten the 4 screws in threaded holes of Heatbed support keeping a distance between this and the hot plate:
HackerBot step 32
Assembling Base
Step 33: Assembling Base
Printer base can do with different materials. Our advice is to use a metal sheet of about 1.5mm thickness or more.
Base dimension is 450x450mm
HackerBot step 33
Put four feets (M8 thread):
HackerBot step 33.1
Electronics
Step 34: Power supply
** PLEASE TAKE CARE! RISK OF INJURY, ELECTRIC SHOCK OR FIRE **
Power supply
1 Switching power supply DC 24v - 12.5A TracoPower TXL 350-24S or Ebay junk
2 Power supply clamps File:Power supply clamp.pdf
4 M3x10 screws, 2x M3 nuts, 2x M3 washer
1 Power inlet Bulgin BVA01/Z0000/11 (RS: 352-1825)
2 Power inlet fuse 230V use a 2A fuse (20mm type) - 110V use a 4A fuse.
1 Power cable 25cm 3x1 power cable
1 Power cable 10cm 3x1 power cable
1 Back panel PMMA
7 Fast-on connector fully insulated type (you also need a crimper) (ex: RS 624-1178)
3 fork type crimp connectors optional
Wiring:
HackerBot Power supply wiring
assemble the back panel with inlet:
HackerBot Power supply inlet
cable all together:
110V / 230V is lethal. Please do not do wirings if you are not a tech and are you very sure what are you doing.
Bulgin inlet is very dangerous because one power joint is not isolated!
PLEASE USE HOT GLUE TO INSULATE ALL THE INLET BACK
HackerBot inlet insulation
DO EARTH CONNECTION TO CHASSIS and DOUBLE CHECK GLUE
YOU MUST PLACE A VERY DEATH DANGER ADHESIVE!
HackerBot voltage danger
Step 35: Controller
Tested controllers are:
  • ARDUINO MEGA 2560 + RAMPS 1.4 + Pololu A4988 / TI DRV8825
  • RUMBA (rep rap discount electronics) with 3 output for extruders and some extras
RAMPS
HackerBot RAMPS
Printed box for Arduino Mega + RAMPS:
  • INSERT
File:Hackerbot step 35.2.jpg
HackerBot RAMPS case
RUMBA
HackerBot RUMBA
Printed box for Arduino RUMBA:
  • INSERT
HackerBot RUMBA case
Step 36: Motor cabling
Motor cabling
2 X and Y motor cable 4x0.25 mm2 , length: 1m (RS: 491-8983)
1 Z motor cable 4x0.25 mm2 , length: 40cm (RS: 491-8983)
2 Panel connectors check photo
* Shrink tube
Wiring scheme:
MOTORPANEL CONNECTORCABLE (LiYY 4x0.25)A4988/DVR8825
RED» 1 «Yellow1A
BLU2White1B
GREEN3Green2A
BLACK4Brown2B
HackerBot cabling
Fix the panel connector (motors):
HackerBot motor panel connector
Wire the Z motor:
HackerBot Z motor cabling
Step 37: Extruder cabling
Extruder cabling
2 silicon cable 1 mm2 length: 1m (red & black)
1 2x0.14 mm2 LiYY cable length: 80cm
1 Panel connectors check photo
* Shrink tube
1 FAN CABLE 2x0.14 mm2 length: 1.5m
NOTICE: ONE EXTRUDER PROCEDURE. (repeat x times if you need multiple extruders)
Wiring scheme:
PANEL CONNECTORCABLEnote
1 «SILICON REDExtruder power +
2 «SILICON BLACKExtruder power ground
3 «LiYY BROWNNTC
4 «LiYY WHITENTC
HackerBot Extruder cabling
In the middle hole put the FAN CABLE:
HackerBot Fan cable
Step 38: Endstop
Endstop
1 X end stop holder File:X Endstop holder.stl
1 Y end stop holder File:Y Endstop holder.stl
2 X/Y end stop 2x0.14 LiYY cable (RS 445-1395) length 90 cm
1 Z end stop 2x0.14 LiYY cable (RS 445-1395) length 60 cm
2 2x0.14 LiYY cable length 90 cm (RS 445-1395)
1 2x0.14 LiYY cable length 60 cm (RS 445-1395)
3 2x1 dupont connector
Use support and 2x M2.5x15 screw set to fix it:
HackerBot X Endstop
Using the support fix it to the structure:
HackerBot Y Endstop
Using 2x M2x12 screw & nut tighten the endstop to the support:
HackerBot Z Endstop
HackerBot Endstop connectors
Step 39: LCD Controller
LCD Controller
1 RepRapDiscount XXL LCD
1 XXL LCD case File:Bottom Case XXL.stl
1 XXL LCD case cover File:Top Case XXL.stl
1 XXL LCD knob File:Controller knob 2.stl
1 XXL LCD kill button File:Kill Button XXL.stl
2 Velcro strips 50x20 mm
HackerBot XXL LCD
Extruder
Step 40: Extruder support plate
1 80 x 120mm Aluminum plate 1.5mm thick
Extruder is mounted on a plate on the back of Hackerbot
Step 41: Extruder assembly
1 Wade "tilt" extruder Wade-Greg Tilt extruder
1 Hobbed bolt with Nylock M8 Nut, M8 nut and 4 washers.
1 bowden adapter
2 M3x20 screw kit for bowden adapter
3 M3x6 motor
3 628 bearing
2 springs 25mm 1.5 thick
2 M4 threaded rod length 70mm
2 square nut M4
2 M4 wing nut
1 8mm rod length 18mm
1 1/8" Pneufit 6mm
1 square nut M3 needed for small pulley
1 M3x6 grub screw needed for small pulley
Hobbed bolt step by step build guide: Hobbed bolt
Hobbed bolt:
Hackerbot hobbed bolt
extruder assembly:
Hackerbot extruder assembly
Using bowden adapter:
Hackerbot Extruder bowden adapter
Mount on the frame:
Hackerbot Extruder
Step 42: Hotends
Using a 40W 24V ceramic heater cartridge and EPCOS NTC wire like this:
Hackerbot hotend wiring
Assemble wiring and hotends, fix it with good nylon strip:
Hackerbot hotend assembly
assemble hotends into head and gently tighten the grub screws:
Hackerbot hotend head
Please remember that hotends heights should be the same
Step 43: Extruder bowden
PTFE bowden tube is 3.18mm inner diameter, 6mm outer diameter and total length of one bowden tube is 750mm
Hackerbot bowden
Step 44: Cabling
File:Hackerbot step 44.jpg
Hackerbot cabling
Step 45: Final check
  • tighten the cubic slider grub screws
  • move cubic slider to one corner and tighten the axis bearings supports
  • repeat for all vertex
  • tighten the GT2 belts and relative pulley
  • double check hotend grub screw and security lock
  • check polarity
  • use oil on shafts
  • grease on trapezoidal screw
Panels
Step 46: PMMA panels
Mount the panels
File:Hackerbot step 46.jpg
Hackerbot closed printer with panel
Accessories
  • Printer tool kit
  • Spool holder
** PRINTER COMPLETE **
>>> How to use an Hackerbot
