Genealogy / Archeology of the Greg's Wade's Geared Extruder
Revision as of 13:50, 8 March 2015 by AndrewBCN (talk | contribs) (Concurrent 6th Gen popular designs: Misan's "Bob's your uncle" and the i3 Rework rotated versions of Greg's Wade's Geared Extruder)
"As long as there is filament, there will be the need to push it - and that what Greg's Wade's Geared Extruder was designed to do."
In this page I will illustrate (to the best of my knowledge) how the original design for the Wade's geared extruder has evolved in the last few years. Nowadays (early 2015) this extruder design is probably the most popular single extruder design among reprappers worldwide, and it has spawned countless remixes. It would be impossible to account for all the variants of this design available on the web but I will try my best to show its main "evolutionary line".
Trivia
Greg = Greg Frost, engineer, Adelaide, Australia.
Wade = Wade Bortz, engineer, Vancouver, Canada.
1st Gen: Wade's original design
This is actually documented right here in the wiki: Wade's_Geared_Extruder and you can find all the files for it on that same page.
Now, I understand that the original Wade's geared extruder from February 2010 is itself an evolution of an earlier extruder design by Adrian Bowyer and also includes many ideas from Nophead's early research on extruders. Wade apparently used Alibre, a proprietary CAD program for Windows, to design his geared extruder.
Wade's Geared Extruder, original version, circa 2010.
All the files for this early extruder design are still available both here on RepRap.org and also on Thingiverse. One should note that as much as it has been improved upon by later derivative designs (see below), the basic features of this extruder remain exactly the same, five years later: a NEMA 17 stepper motor driving a small gear that drives a big gear whose axle is a hobbed bolt that pushes our filament, with compression provided by a spring-loaded bearing.
2nd Gen: (Greg's) Accessible Wade's Extruder
This was published on Thingiverse in February 2011 i.e. about a year after the publication of the original Wade's extruder. Greg redesigned Wade's extruder from scratch using OpenSCAD, a move that imo allowed the design's evolution to really take off.
Greg's accessible extruder, Version 1.
The OpenSCAD source includes references to Josef Prusa's GitHub repository so I imagine the extruder was designed to be used with the Prusa Mendel, at the time the "current" Prusa design.
File header:
// Greg's Wade Extruder.
// It is licensed under the Creative Commons - GNU GPL license.
// © 2010 by GregFrost
// Extruder based on prusa git repo.
// http://www.thingiverse.com/thing:6713
Together with his extruder body design, Greg also published a nice set of gears (gear ratio 10:43), using his own OpenSCAD gear library:
Greg's gears for his Accessible Extruder. Gear ratio is 10:43.
File header:
// Greg's Wade Gears.
// Parametric extruder gears based on prusa git repo.
About a month later Greg published version 2 of his extruder, which is pictured below:
Greg's Wade's Accessible Extruder, version 2.
3rd Gen: Greg's Hinged Accessible Extruder
Greg published the third version of his extruder on Thingiverse in May 2011, about two months after the publication of version 2. The main improvement is of course the addition of a hinged idler, as the name of the thing indicates. This is how Greg describes his improvements:
This is an update to my Accessible Wade's Extruder.
The idler is now hinged using an M3 screw. I have also added support for the central part of the 608 idler so that there is no need to use washers to space the bearing away from the plastic.
I have been using this design for a while now and love it.
Changing filament is a simple as compressing the spring then whipping out the old filament and poking the new one in.
Greg's Hinged Accessible Extruder, body and idler.
The Thingiverse page shows this design was remixed 29 times!
4th Gen: Greg's Guidler
In February 2012 Greg came up with a 4th version of his extruder design, published on Thingiverse as "Guidler for a Gregs Wade", although the newly published thing was really a complete extruder.
Now, why did Greg use the previously unheard of word "guidler"? In Greg's own words:
Some minor changes to my filament pusher inspired by Tom's update (http://www.thingiverse.com/thing:16928). I have incorporated a filament guide on the idler (and coined the term guidler). I also took his modification so the front bearing doesnt rub and I have included a printed spacer so the bottom bearing doesnt rub either (just insert it before the bearing). I also widened the opening a bit for better access to the hobbing (another of Tom's ideas). I also included one of Triffid Hunter's suggestions to modify the hinge support piece slightly to make it easier to remove.
Thanks Tom and Triffid for the ideas.
Wade's Greg's Geared Extruder with a Guidler. And what is a guidler, you may ask?
This thing was remixed 15 times on Thingiverse and among the remixes we'll find what I consider to be the following "evolutionary step" for this extruder design: Greg's Wade reloaded.
5th Gen: Greg's Wade reloaded
In March 2012, just one month after Greg had published version 4 of his extruder, Jonas Kuehling published his "reloaded" version of Greg's Wade's Geared Extruder on Thingiverse. The list of improvements/modifications is quite extensive:
This derivative of Greg's Wade Extruder collects all the best ideas and latest features and improvements:
* Greg's excellent "Guidler" for perfectly lined up filament feed AND easy access of the hobbed bolt
* Tiltable idler-screws for opening the idler without removing the screws entirely
* 4mm elevation of whole extruder body/bolt/motor mount to allow slightly bigger 9/47 herringbone gears
* 2mm extra bolt-motor-distance for the same reason
* M4 nuts and screws for idler, since M3 screws in more than 60mm length are sometimes hard to source (at least in the common hardware stores of northern germany..)
* Well, 9/47 herringbone gears!
* All nut-traps have been corrected for correct fit (all prusa parts seem to use slightly wrong sizes.. should be 5.5mm wrench size for M3 nuts, I changed all of them to the right ISO values with additional 0.2mm clearance. Fits great for a precisely calibrated prusa)
* Additional hotend-mount option "reprapfaborg" for Stoffel15's great hotends that use 10mm shaft diameter of 20mm length (shown on one of the pictures as a cut-view); you can get one via http://reprap-fab.org
* 8mm thickness of motor mount (instead of 10mm) in reference to wider herringbone gear
Greg's Wade's reloaded, extruder body and guidler.
Now for the fishbone gears, there is an important detail that is not very clear: Jonas did not provide the source code for them, he actually edited the STLs from this thing: Thingiverse. I went looking for the OpenSCAD source code for the fishbone gears and eventually I stumbled upon a file with the following header:
File header:
// Wade's Extruder Gears using Parametric Involute Bevel and Spur Gears by GregFrost
// by Nicholas C. Lewis (A RepRap Breeding Program)
// © 2010 by Nicholas C. Lewis
// http://www.thingiverse.com/thing:4305
Greg's Wade's reloaded fishbone gears.
It is quite interesting that Jonas adopted the word "guidler" just one month after Greg had coined it; my guess is the idea was so good that it needed the obvious name that Greg had given it. Another interesting fact is that Jonas' work had so many derivatives (Jonas' thing was remixed a grand total of 67 times!) that 3 years later it has become difficult to distinguish a single evolutionary path from that point on, as there are so many derived extruder designs that are available on the web. Another issue that clouded the evolutionary path here is that Jonas did not add his copyright to the source code, and the only way to distinguish his changes to the source code is using a diff-style program (an automated program that lists the differences between two text files).
I have chosen only two among the dozens of derivatives of Greg's Wade's Geared Extruder available nowadays (early 2015) to show how the design evolved (and is still evolving!) in the last three years.
Misan's "Bob's your uncle" version of Greg's Wade's Geared Extruder was published in March 2013 on Thingiverse and designed for the Prusa i3, the design of which had just been published by Josef Prusa. The Prusa i3 was the "hot new kid on the block" among 3D printer designs at the time and Misan's "Bob's your uncle" version of Greg's Wade's Geared Extruder almost immediately became extremely popular among reprappers building an i3 or even considering a build.
Misan's version of Greg's Wade's Geared Extruder.
Misan's version is based on Greg's code but incorporates some of the improvements/modifications in Jonas's "reloaded" version. Also he is using the exact same fishbone gears as those in Jonas' "reloaded". There is the same issue with Misan's published version as with Jonas' version: he too, forgot to add his copyright or any clear indication of his changes of the source code.
Whereas Misan's version of Greg's Wade's Geared Extruder strove for simplicity, the i3 Rework version of Greg's Wade's Geared Extruder is slightly more original in the sense that it rotates the whole body of the extruder in relation to the X-axis: the gears are now perpendicular to the X-axis. This in fact leads to a rearrangement of the various elements of the extruder but still, it retains all the features that the Greg's Wade's Geared Extruder is known for. Another very important innovation in the i3 Rework extruder is that the layer fan is integrated in the design, it is not an afterthought.
(include picture)
Now, the big problem here is that, contrarily to Misan's work, the i3 Rework extruder design has some serious issues with its copyrights and is not compliant with the GPL:
  1. Source code or CAD files are missing.
  2. Incorrect attribution.
In fact the i3 Rework extruder is a trivial remix of the extruder published by ch1t0 in April 2013 on Thingiverse. By reading the comments I have determined that ch1t0 simply took Greg's design and imported it in SolidWorks (a proprietary CAD program), then made all his changes and added his own original (or not?) ideas. However, ch1to never published his SolidWorks files, thus preventing any further evolution of his design. In fact, by breaking the OpenSCAD design chain, ch1t0 effectively signed the death sentence for this particular "evolutionary line" of the Greg's Wade's Geared Extruder, as far as I am concerned.
7th Gen design trends: Bowden, fans, newer hotends
In late 2014 / early 2015, we are seeing some trends in the continued development of Greg's Wade's Geared Extruder.
