Gas nozzle hot end
Revision as of 20:02, 3 July 2011 by Hariseldon78 (talk | contribs)
NB: The following tutorial need the use of power tools (drill press) in some non-standard way. There will also be dangerous metallic dust filling the room. Also the tools and parts you are machining can easily break, projecting pieces of all dimensions and at high speed. Please wear heavy gloves, anti-dust mask and goggles at all time when using the tools. Some noise protection will be good too. I know it's not confortable working in that way, but you really don't want to loose a finger or an eye, or breathing some alluminium and brass, just to make an hot end.
Gas nozzles come in many different shapes but they all have 1 thing in common: they are really cheap. I paid 6€ for a set of 5. After looking to various models i found the better suited are the "gpl nozzles", with 8mm screw and round body. The inside diameter is 5mm. Don't take the methane nozzles because they have bigger holes. With the smallest gpl nozzle the pla filament i get is something between 0.45 and 0.5 mm which for me is more than satisfying.
My suggestion is to make all the machining with the biggest hole nozzle, so any error in the process won't damage the little hole one, which is the most useful.
To be able to connect the nozzle to the other parts of our hot end we must use the die tool. The screw thread already present on the nozzle is not compatible with usual m8 bolts and nuts, so all become easier if we remake the thread. I used a die of size 8mm x 1.25.
Hariseldon78-gasnozzle-0.jpg Hariseldon78-gasnozzle-1a.jpg Hariseldon78-gasnozzle-1b.jpg Hariseldon78-gasnozzle-2.jpg
Now we want to make the thread on the long side of the nozzle, to be able to mount the heater on it. We start by reducing the external diameter from 10mm to little more than 8mm. I didn't want to damage the thread mounting the nozzle directly on the drill press, so i used an m8 bolt with cutted head and a long nut. Use a cheap metal file (i bought a set of 6 for less than 5€). Be careful not to damage the exagonal part of the nozzle, it is very useful!
NB:I made the photo with the drill press turned off. This is why i'm not wearing gloves. Don't do it without gloves!
Hariseldon78-gasnozzle-3.jpg Hariseldon78-gasnozzle-4.jpg Hariseldon78-gasnozzle-5.jpg
Now using the same die tool used before we make a thread on the other part of the nozzle. Use a bit of oil so you don't damage the tool and go slowly.
Hariseldon78-gasnozzle-6.jpg Hariseldon78-gasnozzle-7.jpg Hariseldon78-gasnozzle-8.jpg Hariseldon78-gasnozzle-9.jpg
This is the threaded nozzle:
The internal diameter of the nozzle is 5 mm, which is a bit too much for our needs. From my tests the nozzle would contain too much melted pla and would be nearly impossible to stop the extrusion.. It works, but not very well. So i decided to reduce the diameter. I cutted a 15x15mm piece of a sheet of 0.5mm aluminium, rolled it around a 4mm drill bit, inserted it in the nozzle and cut the exceeding part, leaving just a bit as you can see in the photo. Probably a little tube of PTFE would be even better, maybe put your experience in this page if you want to try it.
The remaining parts are mostly like the standard nozzles. I drilled a cilinder of PTFE like this:
Hariseldon78-gasnozzle-12.jpg Hariseldon78-gasnozzle-13.jpg Hariseldon78-gasnozzle-14.jpg Hariseldon78-gasnozzle-15.jpg Hariseldon78-gasnozzle-16.jpg Hariseldon78-gasnozzle-17.jpg Hariseldon78-gasnozzle-18.jpg Hariseldon78-gasnozzle-19.jpg Hariseldon78-gasnozzle-20.jpg
