Revision as of 07:34, 13 October 2014 by AndrewBCN (talk | contribs) (After sanding the steel frame parts, rub with a sponge in warm water with detergent and rinse abundantly, then dry with a rag.)
Original file(1,428 × 1,332 pixels, file size: 862 KB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current07:34, 13 October 2014Thumbnail for version as of 07:34, 13 October 20141,428 × 1,332 (862 KB)AndrewBCN (talk | contribs)After sanding the steel frame parts, rub with a sponge in warm water with detergent and rinse abundantly, then dry with a rag.
  • You cannot overwrite this file.
The following page links to this file:
Metadata
