File:OpenX Carriage Full Set.zip
Revision as of 14:05, 10 February 2011 by Buback (talk | contribs) (uploaded a new version of "File:OpenX Carriage Full Set.zip": slight change to the carriage. A test model snuck in before, with one side only 3mm thick.)
OpenX_Carriage_Full_Set.zip (file size: 224 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
stl's and sketchup files
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 12:08, 17 February 2011 | (224 KB) | Buback (talk | contribs) | fixed the all in one file: part bottoms weren't all on the same plane. |
16:54, 15 February 2011 | (235 KB) | Buback (talk | contribs) | added a all in one stl and skp file, if you want to print out all the parts in one go. | |
14:05, 10 February 2011 | (122 KB) | Buback (talk | contribs) | slight change to the carriage. A test model snuck in before, with one side only 3mm thick. | |
15:11, 8 February 2011 | (114 KB) | Buback (talk | contribs) | carriage.stl was broken, fixed in this file | |
20:27, 7 February 2011 | (114 KB) | Buback (talk | contribs) | stl's and sketchup files |
- You cannot overwrite this file.
File usage
The following page links to this file:
