File:Nylon2 elements of smps assembly v1p00.stl
Revision as of 08:45, 16 February 2014 by Rapatan (talk | contribs) (Rapatan uploaded a new version of "File:Nylon2 elements of smps assembly v1p00.stl": extra Low voltage access hole edge removed)
Nylon2_elements_of_smps_assembly_v1p00.stl (file size: 130 KB, MIME type: application/acad)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Nylon1_elements_of_smps_assembly_v1p00.stl 2 of 3 nylon printable elements of metalicaRap smps
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 08:45, 16 February 2014 | (130 KB) | Rapatan (talk | contribs) | extra Low voltage access hole edge removed |
18:11, 8 February 2014 | (217 KB) | Rapatan (talk | contribs) | ||
06:57, 5 February 2014 | (134 KB) | Rapatan (talk | contribs) | Nylon1_elements_of_smps_assembly_v1p00.stl 2 of 3 nylon printable elements of metalicaRap smps |
- You cannot overwrite this file.
File usage
The following page links to this file:
