File:Milling pcbs 06 detail.jpg
Revision as of 07:41, 11 December 2010 by Lanthan (talk | contribs)
Original file(1,200 × 900 pixels, file size: 310 KB, MIME type: image/jpeg)
Detail of pcb milling done on a tabletop cnc. 60 degrees cheap carbide v-bit with 0.2 mm flat end. Right: milled at 0.2 mm depth. Left: milled at 0.1 mm depth. Drill holes seen here: 0.9 mm carbide.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current07:40, 11 December 2010Thumbnail for version as of 07:40, 11 December 20101,200 × 900 (310 KB)Lanthan (talk | contribs)Detail of pcb milling done on a tabletop cnc. 60 degrees cheap carbide v-bit with 0.2 mm flat end. Right: milled at 0.2 mm depth. Left: milled at 0.1 mm depth.
  • You cannot overwrite this file.
The following 2 pages link to this file:
Metadata
