File:AzteegX1 Sang testcode.zip
Revision as of 18:00, 5 March 2012 by Royco (talk | contribs)
AzteegX1_Sang_testcode.zip(file size: 693 bytes, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Arduino test firmware for Azteeg X1 and Sanguinololu 1.3 boards. Based on RAMPS test code. It will Blink the Bed and Hotend LEDs( Azteeg X1 only) and turn on your stepper motors back and forth. As a precaution make sure your motors are centered(or away from either ends of its travel)as this test firmware will ignore your endstops. Disconnect your bed and hot end when using and Check stepper drivers' orientation and current limit before using.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current16:51, 5 March 2012 (693 bytes)Royco (talk | contribs)Arduino test firmware for Azteeg X1 and Sanguino 1.3 boards. Based on RAMPS test code
  • You cannot overwrite this file.
There are no pages that link to this file.
