E1x
Revision as of 21:25, 11 February 2015 by Sphetz (talk | contribs)
E1x
A t-slot 3d printer by tjb1
E1x is a printer designed by tjb1.
Parts
The files for the printed parts can be found here[1].
BOM
Please make sure that this table is up to date with the google docs BOM found here[2] before you purchase/cut your materials!
Note: VXB and McMaster smooth rod will need to be cut to length, Misumi links are for cut materials.
Quantity Size Description Part Number Misumi McMaster VXB Fastenal
4 3mm x 10mm x 4mm Flanged Bearing F623 or F623ZZ [3]
4 30mm x 30mm x 20mm Corner Bracket HBLFSN5 [4]
2 370mm x 8mm X Axis Smooth Rod [5] [6] [7]
2 350mm x 8mm Y Axis Smooth Rod [8] [9] [10]
2 320mm x 8mm Z Axis Smooth Rod [11] [12] [13]
2 20mm x 20mm x 368mm 2020 Extrusion [14]
5 20mm x 20mm x 330mm 2020 Extrusion [15]
2 M5 x .8 - 305mm Threaded Rod [16] [17]
Picture of E1x.
