Category:Wilson
Revision as of 16:34, 2 March 2014 by Mrice (talk | contribs) (Wilson TS)
Introduction | Bill of materials | Assembly
Wilson
A reprap built with Aluminum Extrusions for framing.
Introduction
Reprap Wilson is a descendant of the Prusa i3 style reprap. It also has elements similar to the Lulzbot Taz (particularly the Wilson T Series).
The main goal of Wilson was to replace the frame with one built from standard Aluminum extrusions (2020). Additionally, the design has a parametric build area, meaning it is relatively easy to scale the X, Y, and Z axis within reason. I've also made an effort to reduce the number of unique parts used as much as possible, and incorporated some other design ideas that I have tried on the Prusa i3 previously (monolithic Y ends, easy adjustment of the Z limit switch, integrated endstop holders, among others).
The standard BOM is for a 210mm x 210mm x 200mm build area.
Build Variants
There are two variants of the reprap Wilson design, tentatively called the R and T Series, or simply RS and TS.
Wilson RS
The RS is the original model, with Round (R) threaded rods for the Y axis.
Advantages of the RS:
  • Less extrusions to buy, if you already have or have access to M10 threaded rod.
  • For the same print volume, the RS is shorter (Z axis), which results in shorter extrusions and Z axis rods.
Wilson TS
The TS uses T-slot extrusions for the Y axis (as well as the frame, like the RS).
Advantages of the TS:
  • A single type of framing element is used (2020 extrusion), which simplifies the BOM.
  • The Y axis is more rigid to the frame, which makes front-to-back stress on the frame less likely to cause any wobble.
  • Because the print bed is higher, there is room beneath the bed for a 12V PSU and electronics board.
Subcategories
This category has only the following subcategory.
Pages in category "Wilson"
The following 4 pages are in this category, out of 4 total.
Media in category "Wilson"
The following 20 files are in this category, out of 20 total.
