Case-rap 2.0
Revision as of 23:20, 1 June 2015 by Jlguil (talk | contribs)
This is my 2nd version of the idea of the case-rap.
You'll find more details on this thingiverse link:
http://www.thingiverse.com/thing:824763
Main goals of this project (all acheived!)
  1. Build a portable/foldable full size reprap.
18 x 17 1/2 x 5 inches
24 lbs
200 x 200 x 175 mm
This is the half of the volume of original case-rap!
  2. As cheap as possible: 300$ (cad)
  3. Easy/Fast to build:
I use as less printed parts as possible (combining multiple parts)
The building requires less squareness verification/adjustments as the main body uses as reference.
It took me around 15h building the prototype. I think that next one will take less than 10.
  4. Solid: It doesn't fit in a suitcase, it is one.
  5. Protected: in transport position, no wires can be torn off. Nothing but fragile.
  6. Easiness to find all parts:
The main body is made of plywood, no need specific aluminum extrusions.
Any standard nema 17, ramps 1.4, straps and pulley sets will do the thing.
  7. Easy to use:
I used ramps 1.4, with lcd/sd: Very popular and hackable electronics: So it is usable from a computer or alone from lcd/sd
I installed a inductive proximity sensor: so even if the box is not set the exact 1/100 mm same way every times, this is going to print as good anyways.
I programmed a new option in the prepare menu to set the printer to be ready to be folded.
I worked really hard, and had needed some help (mkeveney), to design super fast hinges to swap from a position to the other. I believe the result is just awesome. Way better than I tough I was going to be able!
  General use video:
  Look at this fast swaping/folding video:
All files are free given to the 3d printing community on thingiverse.
This is unfinished yet building instructions:
https://docs.google.com/document/d/1boXSuS7YWnBhjGcFoZcu-Cw0jY0c_1mK8ykopVRCegU/edit
