Canadian Suppliers
Revision as of 05:41, 15 July 2011 by Jing.guo (talk | contribs) (Steel)
Belts and Pulleys
  • MixShop
  • SDP/SI - "they work fine, but were pretty expensive, the shipping was expensive, and the brokerage fees were expensive too. I'd love to find a Canadian source for MXL belts and pulleys, or anything that would work."
Specific SDP-SI MXL pulleys that work on a Darwin:
Z axis - A 6A16-060DF2508 - 60 tooth 1/4 " bore pulley. Can be tapped out to M8 directly.
useful part numbers A 6R 3-C025 (8 ft required) A 6R 3-185025 (1 required)
Quality Transmission Components 125 Railroad Avenue, Garden City Park, NY 11040-5016 Phone: (516) 437-6700 • Fax: (516) 328-3343
This is the supplier that I found to be the most reasonable as far as prices and shipping. For example the t5 x 840mm is listed as $4.20. They also sell matching aluminum pulleys. Also if purchased online there is no minimum purchase amount.
Electronics
  • Makerbot
  • Digikey.ca
  • Mouser (not really)
  • robotshop.ca
  • sparkfun.com
  • gadgetgangster.com
  • alltronics.com/
  • active123.com/
  • leeselectronic.com/
  • spikenzielabs.com/
  • creatroninc.com/
  • proto-advantage.com/ - Hamilton, Ontario
  • canakit.com/
"Also, if you need electronics, Makerbot is my favorite, but if they're out Digikey is pretty good. They ship to Canada for $10 if you order from digikey.ca, and no brokerage fees. Mouser sent me 50 pages of customs forms detailing every single resistor, cap and chip I ordered for a Darwin, and the brokerage fees cost almost as much as the parts, so I'd stay away from them if you're in Canada."
Steel
  • Metal Supermarket
As for other Canadian suppliers, I found Metal Supermarket usually has stock of 5/16" stainless rod, which works for 8mm smooth rod.
  • princessauto.com/ - they are a surplus store so there stock can change allot but they do have allot of good things most of the time.
  • Generic Steel Suppliers
Check in the telephone directory under "Steel". Your average construction steel supplier sells quite a bit of steel for prices we consider to be very cheap.
Fasteners
  • Fastenal here in Vancouver
  • Peavey Mart - good general store though they are more in the smaller cities and towns.
I've been getting M8 threaded rod from Fastenal here in Vancouver; they usually need to order in larger quantities, but it's usually pretty fast. I also get all my metric nuts and bolts there. I'm quite happy that Mendel uses fewer types of bolts, btw - that makes life a bit easier.
Also try: brafasco/CTF, Canadian Tire (although be sure to check the parts are actually what they're labeled as -- I found their inventory a little disorganized), Metal Supermarket, Atlas Machine Tools on Queen, Jacob's Hardware on Queen, and even Home Hardware in a pinch for metal rods.
  • MixShop.ca
Motors
  • alltronics.com/
  • linengineeringstore.com/ - they will take paypal but i think you have to email them the order www.linengineeringstore.com/general/terms_conditions.aspx it is in here.
Filament
  • Makerbot
  • UltiMachine.com
  • MixShop.ca
computer parts
  • memoryexpress.com/
  • ncix.com/
Regionalization
Each RUG should have a page, but that will have to wait.
Montreal
Ottawa
Toronto
  • creatroninc.com/
  • MixShop.ca
Vancouver
  • canakit.com/
  • MixShop.ca
Waterloo
Working Notes
This page may duplicate another page
We should put up a page on the Wiki regarding Canadian suppliers. I had a look at the Builders Wiki, but I wasn't sure exactly where to stick it. There's a section in the Mendel BOM and Mendel Buyers Guide regarding suppliers, but this might be more general than just Mendel parts.
