Blu Bot 1.0
Release status: unknown
Description | |
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Blu Bot 1.0
The Blu Bot 1.0 is the creation of Professor Valamanesh's Design 3550 Materials and Processes 2015 Spring Semester Course. Team members include: Alex Abele, Tori Boggs, Joanna Celestine, Khanya Keswa, Bill Leonard, Bingyu (Sophia) Li, Carson Long, Jean Paul Pompeo, and Katie Schmiedicker.
The Blu Bot 1.0 is a derivative of the Prusa i3 3D Printer design by RepRap Core Developer Prusajr along with the earlier Prusa Mendel iterations (Prusa Mendel (iteration 1) and Prusa Mendel (iteration 2)).
History
Blu Bot 1.0 started: March 2015
Blu Bot 1.0 finished: April 2015
The course deadline required that the project be started early-to-mid March 2015, ending with the final presentation on April 30, 2015.
Ideation
Objectives
To build a 3D printer that is...
- Fully Operational
- Has Wire Management
- Provides Stable Structure
- Is of Unique Design
- Embodies Functionality and Aesthetic Balance
Initial Concept Sketches
Our initial concept sketches included a variety of forms, however we wanted to develop our 3D printer from a box frame to ensure our final structure embodies the structural support for successful printing.
Narrowed Concept Sketches Our sketches began narrowing to box frames that hide the cords to create a neater and professional look as well as ones which provide a clear viewing screen to show the 3D printing process.
Revision
Practicality
- Plate moves up and down revised to plate moving forward and back
- Viewing side windows
- Hidden motors and rods
Final Concept File:Blu Bot 1.0 Final Concept Illustrator File.pdf
Physical Mock-up 1
Issues
- Not enough space for larger components
- Too small
- Filament placement
- Lack of cord management
Physical Mock-up 2
Issues
- Extra bottom compartment
- Wider side compartment
- Chamfers
- Filament place
- Window cut outs
- Vent cut outs
Integral Changes
- Base structure
- Cord management
- Acrylic support plate
- Power source in a bottom compartment (Isolates heat, easier to cool printer)
- Extruder
Issues
- Too small
Execution
- 3D printed parts
- 2 fried boards
- Rough poles
- Material issues
- T-Joint engineering (have to CNC?)
Specifications
Box Frame | |
Plastic Parts (exc. Extruder) | |
Non-Printed Parts (approx.) | |
Cost | |
Controller Electronics | |
Printing Size | |
Motors | |
Frame Material | |
Frame Manufacture | |
Pro | |
Con |
Materials
SainSmart Package List | Amount |
SainSmart RAMPS 1.4 | 1 |
SainSmart Mega 2560 R3 | 1 |
SainSmart A4988 Driver | 5 |
SainSmart LCD 2004 with Controller | 1 |
SainSmart SD Card Breakout for Ramps | 1 |
SainSmart Cooler Fan for 3D Ramps | 2 |
SainSmart Mechanical Endstop with Cable | 6 |
SainSmart RAMPS 1.4 Wiring Cable | 1 |
SainSmart Heatbed MK2b | 1 |
Thermistor for Heatbed (100K ohm) | 2 |
Borosilicate Glass | 1 |
Aluminium Bed Mount Plate | 1 |
NEMA 17 Stepper Motors Minebea Mill Robot RepRap Makerbot Prusa 3D Printer | 5 |
Assembled J-head Hotend Nozzle | 1 |
GT2 20T Aluminum Pulley | 5 |
GT2 5M Timing Belt | 1 |
USB Cable | 1 |
Materials List | Amount |
Hillman Group 44997 M8 Metric Stainless Steel Fender Washers | 12 |
608ZZ 8x22x7 Shielded Greased Miniature Ball Bearings | 10 |
18-8 Stainless Steel Flat Washer, Plain Finish, Meets DIN 125, M3 Hole Size, 3.2mm ID, 7mm OD, 0.5mm Nominal Thickness | 100 |
LM8UU Linear Bearings for 3D Printer, Prusa Mendel, reprap | 12 |
5x11x5mm Ceramic Ball Bearing | 1 |
BPB5015M12 Blower Fan 12V DC 2P 50mm 15mm 10" wire 2 pins connect 1 pc usa | 1 |
1/4 x 12 x 24 Fluor Blue Acrylic | 1 |
Aluminum Set Screw Rigid Shaft Coupling, w/o Kenway for 3/16" Diameter Shaft | 2 |
Sintron 3D Printer Controller RAMPS 1.4 Arduino Mega Pololu Shield for Reprap Prusa Mendel Arduino Mega2560 | 1 |
PC4-M6 Pneumatic Straight Fitting for 4mm OD tubing M6 6mm Reprap 3D Printer | 1 |
MK8 Drive Gear for Reprap extruder 5mm bore and 7mm Effective Dia Mk-8 | 1 |
Extruder
For Blubot 1.0, we used a variety of standard and modified printed parts. We initially planned to use Prusa I3 parts and a Bowden extruder, not realizing that the Bowden separates the hot end and the cold end of the extruder. This did not align with our design intention, and we found that overall the Prusa Mendel printed parts made for a better fit. We did end up modifying a few of the original Prusa I3 parts: all four z axis corners and all the y axis corners were modified to add a way to secure them to our frame. We changed our extruder to a direct drive hinged extruder modified the extruder head mount to accommodate our slightly larger extruder, and used a newer fan duct design J-Head direct drive extruder. We also added a head-cooling fan E3D J Head cooler with Part vents.
Problems Encountered
Electronic
RAMPS Board
Two boards burned and became useless due to manufacture malfunctions and wiring mistakes. Ordering each one online pushed processes backwards and make it take longer. This would cause for a setback in the assembly of the entire project.
Arduino board
One board burned and became useless due to manufacture malfunction further setting the assembly of the 3D printer back.
Structural
Smooth rods
The rods that came with the kit were imperfect thus the linear bearings would not run smoothly across them (Something highly necessary)
A need to buy alternative smooth rods emerged so zinc-plated smooth rods were bought. These rods came in a set of three, each being a meter long so we had to find metal-working tools in order to cut them and grind down the ends to make them useable.
Frame
What materials to use for the frame of the 3D printer was also problematic. In order to stay within a certain budget, acrylic (the better choice) was replaced with wood. 1/2” wood was bought for its structural support, but a CNC router would be needed to cut these into the many intricate shapes. Then, 1/4” wood was bought as a replacement, and these would be laser cut (A more accessible and time efficient tool).
3D Printing
Fused Deposition Modeling (FDM) Printers
The most accessible 3D printer we have, the MakerBot Replicator 2X, would print in Acrylonitrile butadiene styrene (ABS) plastic. Leveling the platform for this printer proved very difficult and caused many issues including a dislodging of the extruder nozzles when they ran into the platform which causes the extruder to constantly be imperfectly positioned. When buying a differently colored ABS plastic to print with, a plastic spool was bought from a source that was not MakerBot. This spool resulted in a clogging of the first extruder and so the second was relied on to print with. This second extruder was manufactured erroneously and was actually higher than the first, causing for the prints done with the second extruder to be rammed into by the first extruder and create multiple misprints. The Prusa i3 RepRap printer was given to us as the chosen model for our projects. This RepRap model has multiple alterations and the STL parts that they have linked to them are each unique to the specific model and structure. This makes modifications to these parts through Solidworks (Our 3D Modelling software) fairly difficult as the STL parts do not transfer over well.
Sources
Prusa i3 Direct Drive Bowden Extruder
